Will hi-steer work with SUA? - JeepForum.com
post #1 of 1 Old 07-29-2011, 12:14 PM Thread Starter
jeepwhore
I finally picked up the toyota axles and rebuilt engine for my build and I'm running the issues I will encounter putting these axles under my jeep through my head while I'm away at work.
The first issue is the steering box on a toyota is mounted so that the pitman arm is vertical and moves front to back rather than side to side. To make this work toyota used a driver side steering arm with a standard tierod connection off the front and a J-shaped arm off the rear that wraps around the shock to make the pitman arm connection.
The second issue is that the steering is set up like a YJ with the drag link being connected to the tie rod, so the passenger side arm only has one hole in it.
All of this means I will have to replace the steering arms. So far it seems no one makes a set of arms that aren't for hi-steer. So I figure, meh, it's only money (wish my wife thought the same thing ) and will drop $200+ on a set but I'm not sure if hi steer will work with my SUA set up.
The Jeep is staying SUA with a 4" BDS lift and 1/2" shackles.
I don't want to spend that much cake just to run into clearance issues from the tie rod and drag link moving up a couple inches and the frame and track bar etc. being a couple inches lower than they would be if it was SOA.
Thoughts?
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
CJ D30 high steer supraman1990 Jeep CJ Forum 17 01-08-2014 04:00 PM
Can't steer my cj5 cj51967 Jeep CJ Forum 3 09-25-2009 08:32 PM
High Steer for a 60 firejeep196 Jeep CJ Forum 0 02-16-2009 06:05 PM
Can't steer my new '79 CJ7 Pmerritt Jeep CJ Forum 23 05-16-2008 08:12 PM
Will These Rims Work With Waggy Front Axle w/Hi-Steer? Military Jeeper Jeep CJ Forum 3 04-12-2008 01:25 PM
