will the full-time lock hubs on older cj-s replace lockout hubs? - JeepForum.com
post #1 of 3 Old 04-23-2008, 11:02 AM Thread Starter
jeepin cj-5
so i blew up a lock-out hub a while back and am in need of a temporary fix so I can wheel this weekend. A guy I know has an old cj with the fulltime locked hubs. I was wondering if these used the same setup as normal cjs just without the hubs.
1973 cj5- needs alot of work
1985 cj7- SOA w/ Re 1.5" springs, Scout dana 44's, 4.56 gears f/r with full detroit f/r. Flattop knuckles and highsteer. Custom steering with 1 ton TRE's. Procomp es 3000 shocks w/ f250 shock towers. Tom Woods rear d shaft, 37" MTR's... with more and more sh*t piling up
jeepin cj-5 is offline
post #2 of 3 Old 04-23-2008, 06:02 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Depends. If the hubs are off a D30 and have the same bolt pattern they will. However, you will have to use the wheel bearing nuts as well, as they are different. If it is a D27 (1971 and earlier) the axle spline count will be different.
jeepdaddy2000 is offline
post #3 of 3 Old 04-23-2008, 07:27 PM
bjf498
bjf498's Avatar
1983 CJ7
I would say no. Simply because is to much work to make junk work than it is to go buy a set of hubs I think super winch hubs are around 100 bones at 4 wheel parts.com
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline
Lockout Hubs? soonerfan Jeep CJ Forum 7 03-07-2009 07:04 PM
5-Bolt Lockout Hubs CJ-7 ej4x4 Jeep CJ Forum 9 05-30-2008 08:14 AM
4wd lockout hubs redcj576 Jeep CJ Forum 1 04-26-2008 07:11 PM
Lockout hubs question 74cj5360 Jeep CJ Forum 2 02-21-2008 11:15 AM
Lockout Hubs K.C.Jeep Jeep CJ Forum 1 08-08-2005 09:54 PM
