#1 | |
will it fit in my garage?
I am building my 82 cj5 and I am not decided on how big I want to go. I was hoping for 35's 4"suspension lift 2" body lift. The determining factor is my 7' garage door. I have done the math and it will be close. Does anyone with a similar setup have some advise?
#2 |
I have a CJ 7 with 35's but no body lift. I also have a seven foot door opening. With the soft top on it clears by about 3 inches. Without the top I don't have to cringe every time I pull the Jeep in the shop.
1981 Renegade AMC 304 w/35's 1997 SE 2.5 w/31's 2000 4.0 w/33's 2005 GC 4.7 stock |
#3 |
Mine slightly rubs as I drive it in with the soft top on.
With no top, a couple inches clear of the roll bar. 5" springs, 1 " of body lift, 36" swampers ...here's a tip , I adjust the garage door opener to pull the door up as far as possible so that it's fully retracted and the garage door trim is the lowest point
1980 CJ7, Mule Last edited by 1980tallcj7; 12-28-2008 at 08:14 PM.. |
#4 |
You'll be close, but will probably make it. I have a 7-foot garage door. My CJ has 35" BFG's, 4" ProComp suspension lift, 2-1/2" body lift, fiberglass body. I don't have a hardtop for the Jeep, and normally run a Bestop SuperTop. When I go in and out of my garage, the highest point on my top BARELY scrapes the rubber seal at the top of the door header. IOW, I am right at the limit. If I had 36" tires, I'd have to air them down to get into the garage.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc. |
#5 |
I heart bacon and pie
Everybody I have read about in this forum who had a 2" body lift said they wish they had stuck with 1". I just wanted to point that out.
#6 | |
#7 |
SEAL Team VI
Just lay your windshield down and put your roll bar on last and you will have no problem's.
I have a 77 CJ-5 with a 4" lift, 2" shackles with 33" tires, and it makes it in and out of my 7" garage door with no problem. You could also drop your tire pressure if you just needed a little more room? |
#8 |
i have a 93 YJ with 39's and can fit it into my house garage. maybe i have a really high door and celling but it fits fine, with probally 3-4''s to spare.
jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money. |
#9 |
forgot i have a pic.
jason.
#10 |
i have a soa with 1/2" lift shackles and 35's and mine misses by 2 inches. i'd skip the 2"BL, I had one and removed it, didn't look good.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
