Will this early 258 manifold fit on a late 258? - JeepForum.com
post #1 of 2 Old 03-13-2010, 02:28 PM Thread Starter
243
1978 FSJ Cherokee
This is the Edelbrock SP2P I picked up knowing it was for a 258 but not know if it would fit in place of the stock aluminum intake. It looks like it would need longer bolts and this would probably require a exhaust manifold change but I am not sure.
Dave's 78 Build
243 is offline
post #2 of 2 Old 03-13-2010, 02:52 PM
Fjguercio
1978 CJ7
Interesting find. The Edlebrock one has longer mount flages.... that would be a match for the older cast iron exahust manifolds. Cast Iron Exhaust Manifolds were used on my 1978 and I think 79 and was changed in 80 or 81. Might be able to shorten those longer mounts to 1/2" so they can be used with header or modern exhaust manifold.
I also saw a pic of some stand offs pictured here on JF some time back... Used the stand offs with the Tall Edlebrocks Mounts to mate up with std header. Did not look the best but was installed. The long 258 are hard to seal with right stuff, IMO.
All 258s will have the same exhaust port location.
Note the Edlebrock does not have sensor holes... so using a manifold heater below carb a nice thing to have is no longer avail.
Fred
Fjguercio is offline
Intake Manifold connected to Exhaust manifold - delete? attworth Jeep CJ Forum 14 01-19-2012 02:51 PM
Need manifold heater from stock 258 manifold... 243 Jeep CJ Forum 0 03-08-2010 04:57 AM
Fort T18 into late CJ7 TBrock Jeep CJ Forum 11 05-20-2009 09:14 AM
early Jeepster hood on a early CJ? T Hoff Jeep CJ Forum 12 10-22-2008 03:56 AM
Early and late CJ5...differences??? cjthor Jeep CJ Forum 5 07-12-2003 11:50 AM
