Will a carrier from a ZJ low pinion D 30 work in my CJ D 30? - JeepForum.com
post #1 of 5 Old 02-16-2012, 06:27 PM Thread Starter
chet44
I discovered after throwing my rear driveshaft that my inner and outer pinion bearings (AMC 20) are shot. Since I have the dreaded 2.73 ratio, and I'll have to reset the gears anyway, I've decided to bite the bullet and regear both axles now, as well as switching out all of the yokes from the strap type to the U-bolt type. I have a line on a stock Dana/spicer complete 3.73+ D30 carrier with bearings, races, spider/ side gears and center pin, but the owner of them says they are for a ZJ low pinion D 30. For the price he is asking, plus shipping, it seems like a great deal. A bare carrier from Spicer is almost as much. So, as the title says, can I put this in my CJ D 30? Thanks in advance,
Jim
chet44 is online now
post #2 of 5 Old 02-16-2012, 06:49 PM
levergun
1979 CJ5
The carrier is the same. The pinion is different though as the zj uses a crush sleeve and the cj uses shims.
1979 CJ5 408 AMC dana 60/14b, T18, d300, PSC hydro assist
1948 Willys CJ2a LS 4.8/sm465 scout 44's
levergun is offline
post #3 of 5 Old 02-16-2012, 06:54 PM Thread Starter
chet44
That's OK. He has a 3.73 ring gear on it now, but I was planning to gear to 4.10's, so I'd be buying new gear sets anyway. Thanks for the quick response.
post #4 of 5 Old 02-17-2012, 08:05 AM
CSP
Just because it's worth mentioning, the carrier from a high pinion D30 is also compatible.
CSP is offline
post #5 of 5 Old 02-17-2012, 08:57 AM Thread Starter
chet44
Good to know!
Long pinion or short pinion? primezero Jeep CJ Forum 2 08-15-2010 05:26 PM
Pinion Nut WTD???? rrtex1 Jeep CJ Forum 16 06-25-2010 11:02 AM
dana 30 low pinion(cj) want to convert to dana 30 hi pinion(xj) white_cj Jeep CJ Forum 5 12-02-2009 05:41 AM
OR Fab tire/Jerry carrier or TREKs tire carrier? cfernandez Jeep CJ Forum 2 08-23-2009 10:43 AM
Cj Dana 30 carrier same as hi pinion? 4x4chevette Jeep CJ Forum 3 10-19-2005 08:55 AM
