will the axles hold up? - JeepForum.com
post #1 of 4 Old 06-26-2003, 01:12 PM Thread Starter
mixjforlife
swapping in a 360, will the 2-piece 20 hold up to my abuse? even if i upgrade to the one piece will they hold up? and to what tire size is my maximum? want to run 33's
Just Empty Every Pocket
94' XJ Sport 4.0L, 3" rough country AAL, 15X8 panther 5 spoke, 31x10.5 dunlop radial RV, coming soon... a new bumper now
1980 CJ-5 , 258, Dana 300, 4 sp, rust, stock.... for now
mixjforlife is offline
post #2 of 4 Old 06-26-2003, 01:20 PM
mxg342
mxg342's Avatar
The two piece might hold up for a while. All depending how hard you are on the skinny pedal. One piece will be great for 33's.
Some may argue that the AMC 20 rear end w. one piece axles is stronger than the Dana 44
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #3 of 4 Old 06-26-2003, 01:24 PM
Sandman74
I would definately be gentle on the 2piece. The one piece will hold up just fine.
Youth and talent is no replacement for age and treachery.
Sandman74 is offline
post #4 of 4 Old 06-26-2003, 11:17 PM
rustyCJ
buy yourself trail spare shafts and a spare flange. make sure the flange nut is torqued and then drive the piss outta the jeep. if you spin you replace with the spare and get home. you now know that your 360 is too much for the two piece shafts and swap in one-piece axles and sell your old two piece shafts and flanges to some one else looking for trail spares.
the cycle goes on and on until some one is carrying trail spares that have been in bout 5 other jeeps.....
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
cj7 battery hold down mrk3cobra Jeep CJ Forum 18 01-07-2009 12:09 PM
Will a 32rh hold up to a 360? drespecki Jeep CJ Forum 19 10-14-2007 07:09 PM
How much gear oil does a T-150 hold? wwhitby Jeep CJ Forum 2 09-02-2006 06:16 PM
CJ wont run unless I hold key ANJEEP69 Jeep CJ Forum 1 09-19-2005 03:57 PM
will a T-176 hold a GM motor? ImNotRyan Jeep CJ Forum 0 02-26-2003 03:12 PM
