Will this Air Filter System Work Properly? - JeepForum.com
post #1 of 12 Old 09-08-2011, 02:04 PM Thread Starter
82KansasCJ
82KansasCJ's Avatar
1982 CJ7
Seperated this to a different thread from my previous one. I heeded the warnings about the foam type small filter that was on the carb and installed this system that the PO had fabbed up but not installed. I had all the parts. I figure it isn't anyworse than the old one but I'm not sure if this is adequate or not? Give me some thoughts.
New system:
Old system:
1982 CJ-7....not perfect but still alot of fun!
82KansasCJ is offline
post #2 of 12 Old 09-08-2011, 02:45 PM
roadhog304
1973 CJ5
much better setup in my opinion. I had a buddy in high school that had your triangle type filter on his truck and it was a pos. the carb would backfire and that would be the end of the filter.
roadhog304 is offline
post #3 of 12 Old 09-08-2011, 03:34 PM
CSP
It will filter the air coming into the carb.
It's not ideal since it's still bringing in hot underhood air, but it's better than that street rod only in a car show filter you had.
Is that plenum off of a Caddy? I think I have one identical to it.
CSP is offline
post #4 of 12 Old 09-08-2011, 03:37 PM Thread Starter
82KansasCJ
82KansasCJ's Avatar
1982 CJ7
I have no idea what this setup is from as the PO already had it put together.
post #5 of 12 Old 09-08-2011, 03:46 PM
Erik719
1983 CJ7
I put one of those triangular foam filters on a Bug once. When I would floor it the vacuum from the carb would suck the foam down and stall the car
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline
post #6 of 12 Old 09-08-2011, 04:10 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
It is a better set up. Just remember to clean and oil the gauze filters. Otherwise they will allow dirt to pass through.
jeepdaddy2000 is offline
post #7 of 12 Old 09-08-2011, 04:12 PM
hp_lovecraft
1981 CJ5
looks like a grand cherokee one? The dakota/durango are also similar.
hp_lovecraft is offline
post #8 of 12 Old 09-08-2011, 08:08 PM Thread Starter
82KansasCJ
82KansasCJ's Avatar
1982 CJ7
Is here a better brand of this type of filter or is K&N the standard?
post #9 of 12 Old 09-08-2011, 08:39 PM
gojeepin
1983 CJ7
It looks like the one I got from a Caddy.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #10 of 12 Old 09-09-2011, 09:46 AM
JeepHammer
Running On Empty...
1973 CJ5
82 Kansas CJ is 75% on his way to a snorkle with that Cadillac air bonnet,
I did the same thing, but I used some tubing and made a snorkel that works REALLY WELL.
The hard part was finding a gasket for the carb so it didn't leak at the bonnet.
Turned out, Holley has gaskets that work great.
Some guys hook hose to that bonnet and run it through the firewall with ONE of those cone filters behind the dash, just inside the fire wall, but it's NOISY, you hear the engine 'Sucking'...
I did a PVC tubing out the fender well behind the front tire, under the battery tray and up the windshield frame and it works OK, but it won't take a wack from a rock or tree very well...
(Ask me how I found that out!)
Now my side 'Nerf' bars/rock sliders protect it somewhat and I do a lot less replacing the plastic pipe!
I've been looking into that square/rectangle PVC they use for fencing since it glues together like any other PVC and it's cheap...
Should take some of the parts out that stick out too far.
Don't know how it's going to work, but I'm going to try it... I'm sure I'm going to screw it up a dozen times before it works.
Looked kind of funky, but one guy used GUTTERING & DOWN SPOUTS for his snorkel, and it worked suprisingly well!
They make nice turns and elbows for downspouts, so it's not that far out in left field...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #11 of 12 Old 09-09-2011, 06:41 PM
Erik719
1983 CJ7
I like the guttering idea, but wouldn't the diameter be too small to allow sufficient air flow to feed the engine?
'83 CJ7 - Donkey
Erik719 is offline
post #12 of 12 Old 09-12-2011, 07:05 AM Thread Starter
82KansasCJ
82KansasCJ's Avatar
1982 CJ7
I really hadn't given much thought to do a snorkle. I did think of running some sort of tubing from one of the "T" connections to the spacing behind the headlight to try and bring in some fresh air.
what oil filter will work for a 1961 cj5? drew22 Jeep CJ Forum 13 01-27-2011 02:58 PM
Oil Filter Relocation Kit Minus The Filter??? MidJob Darthteddy Jeep CJ Forum 4 07-11-2010 09:11 PM
Automatic transmission not shifting properly?? theplasterman Jeep CJ Forum 15 09-06-2009 09:26 PM
Heating System Does Not Work connor014 Jeep CJ Forum 10 01-07-2009 07:24 AM
fuel gauge not functioning properly atomicflatulenc Jeep CJ Forum 11 07-12-2007 10:53 AM
