Will an '87 soft top fit a '77 Cj - JeepForum.com
post #1 of 3 Old 02-28-2010, 01:13 PM Thread Starter
Dborns
I found a great deal on a Bestop soft top on Craigslist. The seller says its for an '87-'95 Yj, but said it may fit a Cj. Can anyone tell me if it would fit my '77? It does include the hardware.
Thanks
Dborns is offline
post #2 of 3 Old 02-28-2010, 01:22 PM
JimNut
Check out the CJ Stickies thread at the top of the forum. A lot of the answers to the FAQ's can be found there
http://www.jeepforum.com/forum/f8/yj...ion-cj-506688/
Build it, Wheel it, Break it, Fix it and Repeat!
JimNut is offline
post #3 of 3 Old 02-28-2010, 03:17 PM
CrazyHorse6
1979 CJ7
What type of top are you currently running? I'll assume a factory one?
You'll need a couple of key pieces of hardware and will need to overcome a design obstacle:
1) Bestop windshield header. You'll need one of these as I doubt your factory one will work.
2) Channels that run on top of the tub. You probably have snaps and the YJ top will have a plastic lip that folds under and clips beneath these channels. No big deal, but you'll need to install the channels on top of your tub.
3) The YJ has a swing out tailgate while you have a drop down tailgate. The YJ has a special tailgate bar that helps seal the back door and window, so you'll need to engineer something. Check the above post for more info.
Find out what hardware comes with it- might make the deal a lot easier.
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
Soft top doors won't stay shut - full soft doors Cutlass327 Jeep CJ Forum 0 05-18-2009 08:56 AM
CJ5 soft top on a CJ7?? thich Jeep CJ Forum 2 05-03-2008 04:30 PM
Two Piece Soft Doors VS. Lower hard doors with soft upper halves JeepScrambler Jeep CJ Forum 6 10-27-2005 06:29 AM
Steel Door Soft Top on a Soft Door? kilo89 Jeep CJ Forum 6 11-19-2004 01:54 PM
looking for full soft top for CJ-8 & doors hard or soft tarponbooter Jeep CJ Forum 0 02-21-2002 01:28 PM
