Will a 4" trailmaster lift and a 2" body allow for 35" baja claws. - JeepForum.com
post #1 of 14 Old 08-18-2009, 11:20 PM Thread Starter
yojeep79
1979 CJ7
My Jeep has a 4" trailmaster Lift and a 2" body not installed yet. Will that be enough to runs some 35 -12- 50 's
also, anyone running the baja claws, are they worth it. im lookin for good off road and good on road, i know the superswamper tsl are the shizz but they wear out so fast.
yojeep79 is offline
post #2 of 14 Old 08-18-2009, 11:35 PM
19_OIIIIIIIO_41
1987 YJ Wrangler
That lift will absolutely allow for those tires. that should be about perfect for looks and flex.
19_OIIIIIIIO_41 is offline
post #3 of 14 Old 08-19-2009, 07:39 AM
DT5150
1983 CJ7
i think you'd be better off using a 1" body lift instead of the 2", 35's will still fit.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #4 of 14 Old 08-19-2009, 07:40 AM
poppatello
35's will actually fit under just a 4" lift. I tried it on my jeep just to see how it would look and it looks great.
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #5 of 14 Old 08-19-2009, 10:46 AM
19_OIIIIIIIO_41
1987 YJ Wrangler
It all depend on the type of terrain you're looking at getting into. You SHOULD be able to fit 35's with 4 inches. but I'd put more because like obstacle that need a little flex. And I don't think you'd have enough room to flex with ONLY the 4 inches...
post #6 of 14 Old 08-19-2009, 11:00 AM
longboy
2006 WK
Personally, I'd do some trimming and adding alternative flares (TJ flares or tube fenders) before I put 6" of lift on my CJ.
2006 5.7l WK
longboy is offline
post #7 of 14 Old 08-19-2009, 11:24 AM Thread Starter
yojeep79
1979 CJ7
Thanks for the input, I may go with just the 1" daystar rubber body mount.
yojeep79 is offline
post #8 of 14 Old 08-19-2009, 11:26 AM
longboy
2006 WK
What kind of wheels are you running? Still on factory (narrowtrack) axles? You may have a decent amount of rubbing with 35s on factory skinny axles and wheels with factory backspacing.
2006 5.7l WK
longboy is offline
post #9 of 14 Old 08-19-2009, 11:54 AM
78treehugger
1980 CJ7
4" of lift and 35"s wil rub if flexed even a little. The rear wheel well opening will rub. The opening isn't 35" at the bottom. I have 3 1/2" backpacing on my wheels and NT axles (78) and I rub the inner wheel well part of the tub in the rear and the frame where the steering box mount is in the front at full lock and flex. I bent my fenders with 33" Baja Claws with the same lift. I removed my fenders and cut the rear wheel well opening out to clear my 35"s.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
post #10 of 14 Old 08-19-2009, 03:12 PM Thread Starter
yojeep79
1979 CJ7
I have widetracks and After market procomp black wagon wheels..i not to worried about the width just the height. I have 11.50s on there now and they wont rub a bit and there is at full flex plenty of room.
yojeep79 is offline
post #11 of 14 Old 08-19-2009, 04:03 PM
thewolff
Does anyone worry about being top heavy? I have the 4" TM lift and run 33s. Someone told me not to get too tall. Big deal or no?
thewolff is offline
post #12 of 14 Old 08-19-2009, 04:05 PM
longboy
2006 WK
I worry about being top-heavy, but that's why I don't run 6" of lift on my CJ.
2006 5.7l WK
longboy is offline
post #13 of 14 Old 08-19-2009, 08:27 PM
DirtyDevin
1983 CJ7
Yeah, the 1" body looks nice. You can hardly tell its there. And with the right rear bumper you can't tell at all.
DirtyDevin is offline
post #14 of 14 Old 08-19-2009, 09:20 PM
NoNeck
I had the Baja Claws on my 86 CJ with 4 inches of lift. They did not rub on the street and I never wheeled it. I have some pics if you email me I'll send them to you. NoNeck@NoNEcksChevelle.com I LOVED my BAJA CLAWS! They looked awesome and were actually very quiet on the street and rode nice. Sold the Jeep before I got a lot of miles on the tires and again I never wheeled it,. but I would not hesitate to buy the tires again. I am now running Kumho MT 33's with advertised 4 inch lift which ended up netting me 6 inches.
My 84 Jeep website
My Chevelle website
NoNeck is offline
4" Trailmaster Lift Project CJ7 Jeep CJ Forum 2 12-14-2015 11:00 AM
Ugg! Rugged Ridge "stock" length shackles actually 3/8" lift 1984Laredo Jeep CJ Forum 16 12-26-2011 05:12 PM
Can anyone show me what a 4" lift and 1" body on a cj7 looks like with 35" tires yojeep79 Jeep CJ Forum 7 08-22-2009 05:56 PM
jeep cj with 4" trailmaster 4" lift kit yojeep79 Jeep CJ Forum 30 07-29-2009 10:35 PM
4" Lift with 1" body and 35" tires?????? RobP Jeep CJ Forum 14 08-24-2006 07:59 AM
