Will 33's fit a stock 1980 CJ5? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Will 33's fit a stock 1980 CJ5?
The Cure for your Tie Rod Roll!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineOffset Tie Rod Kit From RuffStuff!
Unread 04-19-2005, 08:32 AM   #1
jmerlick
I want to put 33 inch tires on my CJ5 but do not know if they will fit. Any ideas? Do I have a chance for major rubbing on the black plastic fenders?
jmerlick is offline   Reply With Quote Quick reply to this message
Unread 04-19-2005, 08:42 AM   #2
killersheep
I have a freind with a '79 CJ5 and he has a 1" body lift and a .75" shackle lift with 33" tires and they don't rub while we are trailing. I think they will fit but without some lift it, they will probably rub when you start wheeling offroad.
It also depends on how worn/flat your springs are.
86 CJ7 Laredo- '98 4.0L , '94 Fuel Injection and Electronics, 2 1/2" skyjacker, 3/4" Rock Crusher shackle , 1" body lift, T5, DANA 300, D30 front w/Aussie locker , amc 20 rear w/Aussie locker and Moser axles, 3.31 gears, and 32" BFG MT's.
killersheep is offline   Reply With Quote Quick reply to this message
Unread 04-19-2005, 12:08 PM   #3
weedy
You will need at least 2 inches of lift for 33s.
1964 CJ5
weedy is offline   Reply With Quote Quick reply to this message
Unread 04-24-2005, 11:14 PM   #4
garym31
tires
31's will fit nicely on a cj but 33's will rub. You could get a cheaop shackle lift for a temp fix if you want otherwise you will need a body or better yet a suspension lift of at least 2 inches.
garym31 is offline   Reply With Quote Quick reply to this message
Unread 04-24-2005, 11:48 PM   #5
Jeep Daddy
They will rub even if you have a 4" lift if you do any trails that are even somewhat difficult. If it's just a street queen, you could do a 2 inch shackle lift and maybe a 2 or 3 inch body lift to get by. If you cant do that, I'd put 31's on it.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline   Reply With Quote Quick reply to this message
Unread 04-26-2005, 12:01 PM   #6
MR.CJ-7
If you use it, expect rubbing. I have a 2.5" lift with 1" or so shackle lift, and TJ flares. I would rub a little on a full flex situation on the trail without the TJ flares, but now the tires tuck up nicely.
4" lift and consider a 1" body lift or TJ flares to avoid rubbing up front.
Former CJ'er
MR.CJ-7 is offline   Reply With Quote Quick reply to this message
Unread 04-26-2005, 12:52 PM   #7
77 renegade
fit yes..... without rubbing no.heres a pic of my 77 with 33's
WWW.WHEELINDIXIE.COM
77 renegade is offline   Reply With Quote Quick reply to this message
