Wider dana 44 axle - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Wider dana 44 axle
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff's LABOR DAY SALE!FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 09-01-2015, 04:55 PM   #1
tarheel9112
Wider dana 44 axle
I have two Dana 44 axles that I swapping into my 69 cj5. The issue I have is the front axle perches are 3 inches wider on both sides and due to the housing, one side can't be moved. Has anyone done anything where you widened the frame or mount new spring hangers off of the frame about 3" wider then the frame itself? Thank you
tarheel9112 is offline   Reply With Quote Quick reply to this message
Unread 09-01-2015, 05:14 PM   #2
roadhog304
1973 CJ5
Google outboarding jeep springs and you will have all of the info you will need to answer your question.
1973 Jeep CJ5 Amc powered resto-mod
1976 Jeep CJ7 GM powered future 1 ton crawler
roadhog304 is offline   Reply With Quote Quick reply to this message
Unread 09-01-2015, 06:07 PM   #3
skizriz
1978 CJ7
Here's my thread from when I outboarded my springs. Little different due to year and axles, but the basic concept is the same.
http://www.jeepforum.com/forum/f8/my...hread-2812906/
78 CJ7.. 258.. TH400/Dana18.. SOA/stock YJ springs.. 35" General Grabbers.. Waggy 44s.. 4.88 gears...Spartan/Lockright...Fiberglass front to rear
skizriz is offline   Reply With Quote Quick reply to this message
Unread 09-01-2015, 07:24 PM   #4
Newbjeep
1972 CJ5
Not to hi Jack but what's the widest a 5 can go with out out boarding the springs vs nt stock axle
Newbjeep is online now   Reply With Quote Quick reply to this message
Unread 09-01-2015, 08:05 PM   #5
only in a jeep cj
stock 82 to 86 "widetracks" will bolt right in. Minor mod with the front shock mounts.
even wider non stock 44s can have the long side of the tubes cut down, but that major fab.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote Quick reply to this message
Unread 09-01-2015, 08:29 PM   #6
CSP
The problem isn't the width, it's the distance between the spring perches that dictates outboarding. You can't just move them in because of the differential being in the way on one side.
I narrowed a Chevy D44 by 4" to avoid outboarding. WMS to WMS on this axle is 65.5" with eight lugs. Lots of info on this subject on the web.
CSP is online now   Reply With Quote Quick reply to this message
