wide track vs narrow - JeepForum.com
post #1 of 10 Old 10-03-2002, 10:49 AM Thread Starter
cjryder
I've been following the thread started by CJ7danny and got to wondering; when was the switch from narrow to wide track?
Did it occur in both 5's and 7's? I am thinking 1976 on a cj5.
Anyone change a 75 or older to a wide track?
cjryder is offline
post #2 of 10 Old 10-03-2002, 10:58 AM
Bulletproofcj7
I believe somewhere around 1980 they switched to widetrac on the cj7, I am not sure if the cj 5 ever had widetrac from amc.
I put a set of widetrac under my '78 frame that had narrowtrac origionally and they bolt right up!
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #3 of 10 Old 10-03-2002, 11:14 AM
RockJeep
Motobilt.com
RockJeep's Avatar
CJ-5's never came with widetrack axles. but like bullet said they'll bolt up to cj5's from 76-83. 75 in the rear i believe you'd have to move the spring perches on the wide track axle in about 2"s or more per side. plus your cj uses narrower springs, which will work but your spring perches will be wider then the spring. The front should bolt up, but not sure about the steering setup on a pre 76 cj. Is it saginaw?
later
bob
1998 Jeep TJ on 37's, locked, long armed etc
Sales Manager at
RockJeep is offline
post #4 of 10 Old 10-03-2002, 12:28 PM Thread Starter
cjryder
Thanks for the responses. Don't think the steering is saginaw. It is stock 75 cj5 manual. Waiting to see what my latest acquisition has on it. (77 cj5). Also think I'll stay with narrow track.
Small is the reason I like the 5's.
cjryder is offline
post #5 of 10 Old 10-03-2002, 04:18 PM
Jami
1973 CJ6
1982 was the first year that they switched to the widetrack axles on the CJ-7. Just in case you are looking for a donor. Hope it helps.
73 CJ-6 in the works
Jami is offline
post #6 of 10 Old 10-03-2002, 09:55 PM
CSP
Yes the stock steering on your '75 is Saginaw. Jeep began using it in CJ's in 1972. Jami's right about '82 being the first year for wide track on CJ7s. Don't forget CJ8's had them too.
CSP is offline
post #7 of 10 Old 10-04-2002, 08:42 AM
CJ7Danny
Alright... dumb question. Other than Saginaw being a crappy little town in Alabama, what do ya'll mean when you're talking about it with regards to steering?
Dano
85 CJ7 Laredo Hard Top
33" BFG M/T
T176
Moser One Piece Axles
D300, D30, AMC 20, 258 ci
Motorcraft 2100 swap
Nutter By-Pass
Custom front bumpers
Custom Rear bumper/tire carrier
CJ7Danny is offline
post #8 of 10 Old 10-04-2002, 03:40 PM Thread Starter
cjryder
Don't know much about 'em either cj7Danny. Saginaw makes steering boxes and from what I've heard so far, pretty good ones.
I think the heavy duty ones you see on GM trucks are Saginaw.
I did not know that they were in such wide use on CJ's.
(Something else I learned on the forum)
cjryder is offline
post #9 of 10 Old 10-04-2002, 04:06 PM
CSP
Saginaw is the steering division of General Motors. All short wheelbase Jeeps since '72 have used Saginaw steering boxes. CJ's from '76 and up also have Saginaw steering columns. AMC did not make many of these parts themselves because it was more economical to purchase them from GM vs setting up their own designs, plants to make them, etc..
Jeep has lots of other manufacturers parts on them. CJ's from '78-86 use Motorcraft's (Ford) Duraspark II ignition system. Most of the same year CJ's have GM designed alternators.
Just
Everyone
Elses
Parts
CSP is offline
post #10 of 10 Old 10-04-2002, 06:05 PM
CJ7Danny
Cool.. thanks for clearing that up... Oh, FYI...it's
Just
Empty
Every
Pocket
But, you gotta love'm
D
Dano
33" BFG M/T
T176
Nutter By-Pass
CJ7Danny is offline
Axle Swap from narrow track to wide track 1979CJ7newguy Jeep CJ Forum 19 05-02-2013 02:26 PM
Narrow Track gears into Wide Track axles Mike78cj7 Jeep CJ Forum 8 06-03-2011 07:43 PM
Narrow track to wide track swap, mods? greene76 Jeep CJ Forum 8 12-23-2009 09:00 AM
Front axle wide track/narrow track?? Joey_B Jeep CJ Forum 17 10-16-2006 03:44 PM
ring and Pinion swap from Narrow Track to Wide Track From78To83 Jeep CJ Forum 1 04-05-2005 02:15 PM
