Wide track axles vs. Wagoneer axles - JeepForum.com
post #1 of 7 Old 09-29-2011, 11:54 AM Thread Starter
Mlaughlin8
1980 CJ5
How much length difference is there in the wagoneer dana44's and factory widetrack Dana 30/ model 20 axles??? Also how hard is it to swap out wagoneer 44's in a narrow track cj5?
Mlaughlin8 is offline
post #2 of 7 Old 09-29-2011, 01:47 PM
Chewtoy
1976 CJ5
NT Waggy axles are ~61", NT CJ axles are ~51" WT CJ Axles are ~ 54".
"How hard" is a depends on your fabrication skills and what you are doing with the springs. SOA? SUA? Either way you will have to outboard your front springs.
There is a metric crap ton of info on this board alone on this swap. Search is your friend!
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #3 of 7 Old 09-29-2011, 02:02 PM
CSP
Those numbers aren't really apples to apples. The NT Waggy length there looks like a front axle width (though a little narrow, but wider than a rear) and the CJ widths listed there look like rear axles.
Fronts are a bit wider in each case, but a NT FSJ axle is generally about 4-5" wider than the respective CJ WT axle.
CSP is offline
post #4 of 7 Old 09-30-2011, 12:00 AM
Chewtoy
1976 CJ5
My apologies.
Dana 30 CJ NT 53" WT 56" Waggy 44 FT ('74-'79) 61.5"
AMC 20 CJ NT 51.5" WT 54.5" Waggy 44 RR ('80s) 59"
Chewtoy is offline
post #5 of 7 Old 10-01-2011, 10:18 AM Thread Starter
Mlaughlin8
1980 CJ5
What about scout dana44's? How do they compare to stock jeep axles???
post #6 of 7 Old 10-04-2011, 07:13 AM
CSP
Scout 44's are almost as wide as narrow track FSJ axles.
CSP is offline
post #7 of 7 Old 10-04-2011, 11:01 AM
foggybottombob
Scout and Waggy Dana 44 front axles are only 1/4" difference in width if you have the same outers on them. I have a waggy D44 on my XJ and a scout D44 on my CJ7. So the 61.5" WMS to WMS is about right for either one with chevy/Jeep knuckles and ford hubs which is the common way to go.
The rear Waggy D44 axle is 59" WMS to WMS (late 80's model) and the Scout II rear D44 axle is 58" WMS to WMS.
I had a scout axle on the back of my CJ7 for about 3 years.
foggybottombob is offline
