wide track axles on a narrow track CJ7 - JeepForum.com
post #1 of 2 Old 05-28-2004, 11:37 AM Thread Starter
81cj7
I have an 81 CJ7. I am have some axle problems and have been offered a set of wide track axles from an 83 model. Will these axles bolt directly in? Is there anything special I should be taking into account for the installation: brake lines, etc.
Thank you in advance for the assistance
VA jeeper, Charles Shrader
81cj7 is offline
post #2 of 2 Old 05-28-2004, 12:15 PM
motoxxxguy
1995 XJ Cherokee
They should bolt right in, providing there isn't some unforseen circumstance. The wide track axles are simply a little wider, everything else is the same. You will need the drag link and tie rod from the wide track front axle too.
1995 XJ
motoxxxguy is offline
Narrow Track gears into Wide Track axles Mike78cj7 Jeep CJ Forum 8 06-03-2011 08:43 PM
Narrow Track Look on a Wide Track Axles mtndew1 Jeep CJ Forum 11 12-23-2009 02:48 PM
Axles Narrow Track or Wide Track jmdkb12 Jeep CJ Forum 2 04-05-2009 07:45 AM
Wide or narrow track axles on my 83 cj7? muddyjeepguy85 Jeep CJ Forum 4 08-04-2008 09:12 PM
ring and Pinion swap from Narrow Track to Wide Track From78To83 Jeep CJ Forum 1 04-05-2005 03:15 PM
