Wide track 86' Laredo Lift / Tire size question - JeepForum.com
post #1 of 5 Old 07-15-2012, 04:43 AM Thread Starter
JeepinInTheSE
I'm sure that someone on here has covered this before, but I'm looking for some knowledge on what size lift I would need to run 35" BFG A/T tires on my 86' Laredo with wide track axles. I don't really want to trim the fenders. I know that Backspacing plays a roll, and that the tire width / knobs play a roll, but any help would be greatly appreciated. Would like to keep a "relatively low" center of gravity.
JeepinInTheSE is offline
post #2 of 5 Old 07-15-2012, 07:40 AM
gojeepin
1983 CJ7
Without trimming, there's not much chance of raising the center of gravity.
Lift and trimming: You're going to need about 5" of lift and if you plan on going off-road you'll need to trim the rear of the wheel well opening on the tub.
Wheels: for a 10" wide rim you'll need about 3.75" backspacing for a 12.5" cross-section tire.
To get by with less lift, you can use bump stops to keep the axle from impacting the body but that decreases the suspension flexibility and transfers impact energy directly to the frame when encountering tall obstacles.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 5 Old 07-15-2012, 09:02 AM
papa355
1977 CJ7
One thing he has going for him is the BFG's measure short compared to everthing else vs. advertised height. 35" BFG's may only measure 33.5 or barely 34" in real life (not off manufacturer's chart)
My MTZ's only measured 34.75 mounted and aired up (15x10 wheel)
1977 CJ7, 360 AMC with HEI, TH400 quadratrac, dana30, AMC20, SOA, 35" M/T MTZ
papa355 is offline
post #4 of 5 Old 07-16-2012, 02:04 AM Thread Starter
JeepinInTheSE
gojeepin, I see you have TJ fender flares on your rig. How well to they contour to the body after cutting the fenders? Are you happy with the TJ flare conversion?
post #5 of 5 Old 07-16-2012, 04:47 PM
gojeepin
1983 CJ7
Those are Rugged Ridge CJ Pocket Flares. They fit well and I don't have mud thrown on me any more.
I only cut the rear of the tub... the front didn't need it. Except for the rear, I painted all body surfaces under the flares flat black rather than cut.
gojeepin is offline
35" tires , lift kit advice , wide track
cj wide track question pasadena Jeep CJ Forum 1 11-23-2011 11:00 AM
Wide track D30 question zombiesmasher13 Jeep CJ Forum 2 06-30-2011 05:38 AM
Can I use narrow track carrier bearing caps on a wide track axle aero mech Jeep CJ Forum 10 01-26-2011 02:22 PM
Narrow to wide track steering question supraman1990 Jeep CJ Forum 9 04-23-2007 09:26 PM
Wide track axle conversion question only in a jeep cj Jeep CJ Forum 2 08-27-2002 03:21 AM
