Why your steering wanders or seems loose. - Page 6 - JeepForum.com
 2Likes
post #76 of 337 Old 03-14-2008, 12:18 PM
DT5150
1983 CJ7
ahh... that explains it. thanks fatman. i guess i'll have to look elsewhere for the cause of my wandering, but there's one thing i can cross off the list. tie rod ends and spring bushings are next.
DT5150 is offline
post #77 of 337 Old 03-20-2008, 03:51 PM
WacoKid
Hi everybody, new guy here. Just jumped headfirst with purchase of 95 Wrangler and have started going over it bit by bit to get everything in good working order. The steering has a little play in it and it's a white knuckler over 45 mph so steering seemed like a pretty good place to start after the new radiator.
I found some looseness at the lower pittman arm attach point and figured my problem was going to be easy. I stumbled onto this thread while reading about it and after further review I think I need to correct my shims.
This jeep came with a 4" lift "installed by a professional" so the previous owner said. I was looking at it after I read thru here and I have no shims in front but shims in back. I'm thinking I need to switch the shims to the front after reading here.
I'm a little confused though, earlier in this thread someone says to put shims with fat end towards the front. there's a picture in reply #59 that says it's driver side picture which would make fat end of shim to rear?
WacoKid is offline
post #78 of 337 Old 03-20-2008, 04:20 PM
80cj
80cj's Avatar
1980 CJ5
Leave the shims n the back. They were put there to cure drive shaft vibrations. Before doing anything to your front end other than simple repairs, you may want to take it to an alignment shop to get a better idea of what needs to be done.
80cj is offline
post #79 of 337 Old 03-22-2008, 04:48 PM
drunkenrich
1980 CJ7
i just put a AGR steering box on my 80 cj and it solved everything, do the box. it's worth it
drunkenrich is offline
post #80 of 337 Old 03-23-2008, 07:36 PM
ajeepman
It is a picture of the front drivers side looking from under the jeep so fat end is facing front.
ajeepman is offline
post #81 of 337 Old 03-23-2008, 08:44 PM
307cj7
307cj7's Avatar
1980 CJ7
how much was it wondering.... mine is only in the turning it seems to be goofy when you correct to go straight.... what was your doing..... it goes straight down the road though.....
80 CJ7 with 307 chevy motor
BRAKES GOOD, TIRES FAIR
ITS A LIL UGLY, BUT THE KIDDO LOVES IT
Colorado Jeep Club Member # 9999
307cj7 is offline
post #82 of 337 Old 03-23-2008, 09:11 PM
80cj
80cj's Avatar
1980 CJ5
The right side of the picture is the front of the Jeep so the thick end of the shim is facing front which increases caster angle.
80cj is offline
post #83 of 337 Old 03-24-2008, 06:07 PM
ajeepman
Thanks...better answer than the way I worded it. I just wanted to make sure he knew it was correct as pictured.
ajeepman is offline
post #84 of 337 Old 03-24-2008, 07:54 PM
80cj
80cj's Avatar
1980 CJ5
ajeepman,
I imagine your explanation was pretty plain but I'm just a picky old bastard
80cj is offline
post #85 of 337 Old 03-25-2008, 05:23 AM
atomicflatulenc
Had my shaft replaced yesterday, and what a difference. No more wandering. The upper bearings were shot, and the lower bushings were non-existent. It was almost 25 years old.
'85 CJ7, 258 4.2 Howell TBI, NP435, twin sticked Dana300, 4.56 Yukon chromoly: Rear20-extra thick tubes, shaved,trussed,discbrakes,ARB: Front30- flipped tierod,Detroit EZ locker, warn hubs: 3.5" BDS YJ springs and booster, 35" Trxus M/T's, rhino'd, full roll cage, borgenson steering shaft, big daddy steering box bracket...Unknown OIL Leak(working on it...)
FOR SALE $6000
atomicflatulenc is offline
post #86 of 337 Old 03-25-2008, 02:29 PM
drunkenrich
1980 CJ7
300cj7 it was wondering just like yours, do the box, well worth it
post #87 of 337 Old 03-25-2008, 04:56 PM
307cj7
307cj7's Avatar
1980 CJ7
you got a website... how much was it???
307cj7 is offline
post #88 of 337 Old 03-25-2008, 07:46 PM
drunkenrich
1980 CJ7
right now 4wd.com is offering free shipping on AGR boxes. it was about $300 i think or a little more, i didn't install the pump they recommend, you don't need it, use orriginal one. also it's very easy to do if you are good with tools. best swap i did so far, so much mre control. some people will say not to go AGR but i like mine and have no problems. you might want to get a brace for the box too for like $50, you can even sell your old steering box on ebay for $70 like i did to get some money back. pm me with any other questions
post #89 of 337 Old 03-26-2008, 05:13 PM
307cj7
307cj7's Avatar
1980 CJ7
sweet.... thanks man.....
307cj7 is offline
post #90 of 337 Old 03-29-2008, 07:56 AM
EtownCJ5
1982 CJ5
I believe I'm going to try this to help my steering. Just to confirm what I've read about this and shackle lifts:
First pic is 2 degree pos castor angle (taken from the bottom for picture, but also go the same at the top and on passenger side)
Second pic is the 3 1/2" measurement between bolts on the shackle. 3" is stock, so I feel ok about not having to swap shackle at this time (there is a second set of holes on the shackle at 5")
So I'm concluding I need 2 degree shims. Correct?
EtownCJ5 is offline
ball joint , camber , caster , drag link , loose steering , tie rod , Tie rod end , toe in , toe out , wander , wandering , wheel bearings
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
loose steering wheel....not loose steering meater Jeep CJ Forum 3 02-19-2008 02:06 AM
why steering wanders aero mech Jeep CJ Forum 2 08-28-2007 06:45 PM
Loose Steering? GittinAJeep Jeep CJ Forum 6 07-08-2007 08:18 PM
Steering Wanders Badly. JeepinYahoo Jeep CJ Forum 13 06-18-2007 01:55 PM
Steering is loose, wanders back and forth sharkbait Jeep CJ Forum 1 05-08-2006 09:25 AM
