Why your steering wanders or seems loose. - Page 3 - JeepForum.com
 1Likes
post #31 of 337 Old 10-16-2007, 06:27 PM Thread Starter
jadams68
jadams68's Avatar
Good point on the RE shims... you don't want those. You want CJ width shims (2"). Tom Wood at www.4xshaft.com should help.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #32 of 337 Old 10-16-2007, 06:28 PM
DT5150
1983 CJ7
yep, i gotcha... can i do it w/out jacking it up and pulling the tires?
DT5150 is offline
post #33 of 337 Old 10-16-2007, 06:31 PM
DT5150
1983 CJ7
yeah for some reason i was thinking 2.5 would apply to yj's...
i don't see em on 4xshaft, i'll just call or email them after i figure out which size i need.
DT5150 is offline
post #34 of 337 Old 10-16-2007, 06:34 PM
Fatman
Fatman's Avatar
2008 CJ7
This might explain it for ya with pictures:
http://www.jeepfan.com/projects/caster-adjustment.htm
Thread Links:
Fatman is offline
post #35 of 337 Old 10-16-2007, 06:43 PM
DT5150
1983 CJ7
sweet, thanks!
DT5150 is offline
post #36 of 337 Old 11-04-2007, 02:27 AM
velecasa
there sometimes called protractors(angleometer)
velecasa is offline
post #37 of 337 Old 11-06-2007, 09:58 AM
DT5150
1983 CJ7
a couple more questions..
do you just do the front axle, or does the rear need to be checked/adjusted as well?
shims; steel or aluminum?
DT5150 is offline
post #38 of 337 Old 11-06-2007, 10:33 AM Thread Starter
jadams68
jadams68's Avatar
Just the front. Only use Steel shims.
jadams68 is offline
post #39 of 337 Old 11-06-2007, 10:44 AM
DT5150
1983 CJ7
ok, thanks for the info. she's in the shop today get the timing tweaked and having the pinion angle checked. then i'll order up the shims i need...
DT5150 is offline
post #40 of 337 Old 11-12-2007, 08:21 AM
gronked
loose no more
This is a little off kilter, but we installed a Pontiac ws-6 steering box and improved the ratio from 1000:1 to omg:1
Vast improvement in highway steering, and a direct swap for $50. Any camaro or firebird box is an improvement, but the z-28 and ws-6 are the primo's.
gronked is offline
post #41 of 337 Old 11-12-2007, 09:30 AM
lou h
1979 CJ5
It Works
Put these on this weekend. Made a huge difference on my 79 CJ5 with a 4" lift. Had to plasma cut the shims to fit the 2" wide springs... shoulda told Tom Wood what I was putting them on... It does seem like you are mounting the shims opposite of what you should until you realize you are modifying the angle in front of the axle for the steering... not the rear for the driveshaft.
Dirty Juice II
lou h is offline
post #42 of 337 Old 11-19-2007, 03:48 PM
BIGM
I have heard some people that have had these problems even suggest a negative camber, any experience with that? I have a positive one and still have serious wandering problems.
BIGM is offline
post #43 of 337 Old 11-25-2007, 04:09 PM
mike4089
so exactly which way do the shims need to go...im getting mine ths week and i dont want to mess it up...im going with the 4 degree ones since my castor measured zero degrees
mike4089 is offline
post #44 of 337 Old 11-25-2007, 05:31 PM
80cj
80cj's Avatar
1980 CJ5
The shims are installed between the spring and the axle with the thick side of the shim facing forward. Hopefully you are getting steel shims. They should be drilled and fastened to the spring pack with the spring center bolt.
80cj is offline
post #45 of 337 Old 12-28-2007, 12:10 PM
urbanlegend
Anybody have pics of the shims installed? Before and after maybe? Would be appreciated - you guys rawk.
urbanlegend is offline
ball joint , camber , caster , drag link , loose steering , tie rod , Tie rod end , toe in , toe out , wander , wandering , wheel bearings
loose steering wheel....not loose steering meater Jeep CJ Forum 3 02-19-2008 02:06 AM
why steering wanders aero mech Jeep CJ Forum 2 08-28-2007 06:45 PM
Loose Steering? GittinAJeep Jeep CJ Forum 6 07-08-2007 08:18 PM
Steering Wanders Badly. JeepinYahoo Jeep CJ Forum 13 06-18-2007 01:55 PM
Steering is loose, wanders back and forth sharkbait Jeep CJ Forum 1 05-08-2006 09:25 AM
