Why your steering wanders or seems loose. - Page 11 - JeepForum.com
 1Likes
post #151 of 337 Old 01-25-2009, 10:11 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Originally Posted by JavaTee View Post
LT1, Please help my ignorance. Telling me it's unsafe, and not giving me the WHY doesn't inform me on the hazards of shimming the front. I read your previous post on the spring pins possible failure, is that the only problem? If so, is there some way to fix it/strenghten it?
My issue is/was a 3" lift, with some Currie greaseable shackles (1/2" longer than stock). That threw/rotated my C's froward, ie caster off, and pinion angle off. To rotate everything back I opted for shims.
So, should I cut off my spring perches, and reweld them back? or something else. Again, just looking for options. I like safety first.
Later, T.J.
T.J.,
First, Please list your alignment specs,
Then I can better lead you into the right direction.
An alignment is the only correct way to determine correct specifications.
I could tell you it's unsafe to jump off a bridge,
but you would still like the specific reason why it's unsafe.
The reason not to shim the front end is simple.
It's unsafe, It's not the proper way to fix it, It's illegal !!!
Your not only risking your life, But everyone else out driving your roads.
What makes them so bad?
Your Jeep creates a certain amount of rolling momentum. Whenever the brakes are applied, roughly 70 percent of the vehicle's weight is transferred to the front axle. This pitching action causes the front axle to roll forward, thus applying extreme pressure on the front U-bolts and springs. When you add a block shim into the equation it elevates the leverage point on the front axle, causing the axle roll to become even more dramatic. Enough force or pressure can be applied to shoot the front block shim out from between the axle and the spring. This will result in loss of steering, braking and front end control.
Also as mentioned, the pin can shear off, or since the shim has now sucked up length of the pin it is easily possible for the axle to slide off the spring pin due to the lacking depth of the pin.
LT1CJ7 is offline
post #152 of 337 Old 01-25-2009, 10:13 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Originally Posted by gojeepin View Post
The stock Dana 30 spring perches are thick enough to achieve the proper angle by grinding. I removed enough material to change the angle 4* and still have room for the centering pin.
Great way to do it on the cheap and still remain safe and legal.
LT1CJ7 is offline
post #153 of 337 Old 01-25-2009, 11:50 AM
incynr8
1974 CJ5
Well I've been working now on a 1974 Renegade I picked up fro about 2 weeks. It was a struggle to drive with multiple problems. I just discovered the main reason mine wouldn't go straight...........Besides loose U bolts (very loose, nuts came off by HAND!), sloppy springs, a botched add a lift, and worn tie rod ends...the list goes on....... but the killer.......... (cue music)
The rear axle was perched on the pins into the 'other' holes in the perch, instead of the center, on the driver side, pitching the whole axle into pushing the Jeep right all the time....Gotta love POs.!
On the shimming, I am replacing the alum ones for the rear with much thinner machined steel ones. The alumn ones have to be so thick where the steel are thinner and stronger for the back pinion angle, since rewelding axles isn't an option for me right now.
If you are going to use shims at all, use steel ones. It isn't the best to use them front or back really, but if you do, use steel, the alumn ones have to be much thicker for the same angle and still crack/shear, break in half, shear out, kill the pin.
Good machines ones will have a thinner profile to do the same job, have a machined spot to keep the center pin screw shaft straight and take up less in the spring stack. I will agree with all the above posters correcting these things at the axles for pinions /balljoints for caster IS the best way.
incynr8 is offline
post #154 of 337 Old 01-25-2009, 12:19 PM
Bakunin
Bakunin's Avatar
Edit: oops, I guess this isn't stickied though the first post says it should be Mea culpa.
I really don't understand why a post is stickied, which implies that it contains the best advice, when the truth is that shimming your front end is not only the wrong way to do things, but is also quite dangerous.
Sure, it's easier to stick a shim on the axle to give you "safer" caster, but overall you are making your vehicle less safe. The right way to do things isn't as easy, but it might save your life, or the lives of your loved ones.
How great would I feel if my cheap-o quick fix was the cause of my kid being hurt? I might never be able to forgive myself.
Safety first and foremost!
Bakunin is offline
post #155 of 337 Old 01-25-2009, 04:52 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Yes, it is a sticky
LT1CJ7 is offline
post #156 of 337 Old 01-25-2009, 07:33 PM
Rollbar
1984 CJ8
I guess all of us need to remove our shims from the rear & the SOA set ups as well.
<----Click
<---- Click
Rollbar is offline
post #157 of 337 Old 01-25-2009, 07:40 PM
gojeepin
1983 CJ7
Not necessarily... but I would.
I used steel shims on the rear before I changed axles and it sheared off the spring's centering pin. I don't know why.
I mounted new perches on the new axle and welded them to the correct postion.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #158 of 337 Old 01-25-2009, 09:09 PM
Bakunin
Bakunin's Avatar
hmm
Originally Posted by LT1CJ7 View Post
Yes, it is a sticky
I guess I can't tell which are stickied in these forums. The ones I administer, the stickies stay at the top of the forum.
Bakunin is offline
post #159 of 337 Old 01-25-2009, 09:16 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Top of the CJ forum "CJ STICKIES THREAD (FAQs)" 7th link from the top
LT1CJ7 is offline
post #160 of 337 Old 01-25-2009, 10:56 PM
Fjguercio
1978 CJ7
So why are shims for spring perches illegal???
This thread has been going on for months... first I have read of this.
The shim once selected could be tack welded to the spring perch.
The shims could be drilled for the perch pin... could also use a pin extension
Fjguercio is offline
post #161 of 337 Old 01-25-2009, 11:28 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Originally Posted by Fjguercio View Post
[B]So why are shims for spring perches illegal???
Because it's the law in some states.
LT1CJ7 is offline
post #162 of 337 Old 01-25-2009, 11:39 PM
Bakunin
Bakunin's Avatar
I'm not as concerned about illegal as I am about unsafe. Whenever you modify your suspension you have to be sure you maintain the integrity of the system being modified.
Bakunin is offline
post #163 of 337 Old 01-25-2009, 11:40 PM
lvfrogprincess
1993 FSJ Cherokee
I apologize if this question repeats any listed above. I bought my '93 cherokee in June. It came with a 3-inch lift on it. My steering was working perfectly until about November, when it started feeling like it slipped a little as I turned the wheel. It's gotten worse since then, but it is a sporadic problem that never seems to act up when someone else goes to look at it. Today when I started driving it, I could turn the wheel about half a turn before anything affected the direction the car was going. All the parts seem to be in working order, and the power steering fluid is normal. Any suggestions about what might be causing this? We hypothesized about the weather (the car used to live on the coast of California, and now lives in Flagstaff with me, where it's around 0 at night) but it seems to do it anywhere. Any help would be much appreciated!
lvfrogprincess is offline
post #164 of 337 Old 02-23-2009, 05:36 AM
scottymac62
1979 CJ7
I welded my shims on my front spring perches. They won't be moving around on me. It's basically the same thing as remounting your spring perches to achieve the correct caster angle.
Another thing. If you measure the degree of the slope your vehicle is sitting on before you measure your caster angle, then subtract it or add it (depending if you're facing up hill or down hill) you will come out with the correct angle measurement. As long as you have a solid reference ( and know a little math), you can work around just about anything in the construction world.
scottymac62 is offline
post #165 of 337 Old 02-23-2009, 10:47 AM
jeepskate
Some folks complained about the number of stickies, so the 'master' sticky was created with links to the formerly stickied threads.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
ball joint , camber , caster , drag link , loose steering , tie rod , Tie rod end , toe in , toe out , wander , wandering , wheel bearings
loose steering wheel....not loose steering meater Jeep CJ Forum 3 02-19-2008 03:06 AM
why steering wanders aero mech Jeep CJ Forum 2 08-28-2007 07:45 PM
Loose Steering? GittinAJeep Jeep CJ Forum 6 07-08-2007 09:18 PM
Steering Wanders Badly. JeepinYahoo Jeep CJ Forum 13 06-18-2007 02:55 PM
Steering is loose, wanders back and forth sharkbait Jeep CJ Forum 1 05-08-2006 10:25 AM
