why won't my heater work? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > why won't my heater work?
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 09-22-2013, 11:48 PM   #1
cwig12
1983 CJ7
I just had a brand new heater core put in but when I turn the fan on and set the pull knobs to vent heat in it just blows cold air. And if I pull far enough it just closes my vents instead of blowing hot air let alone any air. Is there some trick to it that I'm missing?
This is a 1983 CJ7 Laredo, stock.
Creative-X 3D Printing and Design
Place orders through: creativex3dprinting@gmail.com
cwig12 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2013, 06:17 AM   #2
lucdog
lucdog's Avatar
1980 CJ5
Control cables ( not really a cable, it's a solid wire in a sheath) not hooked up correctly . Or broken, possibly the "cable" inside the box itself.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 09-23-2013, 08:26 AM   #3
walkerhoundvm
1981 CJ8
Mine tends to blow hot air no matter how I have my cables positioned. I'd be worried your heater core is junk.
Are the supply and return hoses getting hot? If both of those are hot, then I'd be looking at why the heat isn't hitting your feet - like a cable problem or something.
walkerhoundvm is offline   Reply With Quote Quick reply to this message
Unread 09-23-2013, 01:40 PM   #4
hp_lovecraft
1981 CJ5
When you pull the "temp" cable, you should be able to see the other end attached to he heater box. Its all the way on the left/bottom side. It actuates a door instead the box that directs the air through, or around the heater box.
If that is working properly, and the heater hoses are hot, then it might be your "vent" knob? It needs to be in the "middle" setting, otherwise the fresh air does not blow over the heater core. Was the vent cable attached? It is a huge pain in the butt to get that cable back on that lots of people forget about it, or its incorrectly adjusted
hp_lovecraft is offline   Reply With Quote Quick reply to this message
Unread 09-23-2013, 02:12 PM   #5
cwig12
1983 CJ7
Thanks, I'll have to take a look. I know when I looked down there the first time my duct wasn't even connected to the vent that directs the air to my feet. So I guess it's safe to assume they forgot to connect a few things.
Unread 09-24-2013, 09:50 AM   #6
cwig12
1983 CJ7
I found the problem. Whoever connected my cables up switched the defrost and temp cables.
