Why are there no cold air intakes for a CJ? - Page 2 - JeepForum.com
post #16 of 37 Old 09-03-2010, 01:15 PM
indiandog
thanks
indiandog is offline
post #17 of 37 Old 09-03-2010, 01:26 PM
swatson454
1983 CJ7
You might be surprised how much difference cool air makes, especially on a super hot manifold.
I'm hoping to have a true, cool air kit for us Weber guys by next summer.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #18 of 37 Old 09-03-2010, 01:30 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Try here, shop by Vehicle
Jeep Parts, Jeep Accessories, and Jeep Soft Tops from The Jeep Parts Specialists | Morris 4x4 Center
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #19 of 37 Old 09-03-2010, 02:11 PM
CSP
Originally Posted by 81CJUSMC View Post
if the OEM is such a good option to keep, why is it that you see a lot of carbs with little rectangular filters mounted directly on top, in a lot of the pictures in a lot of the posts on here? I can imagine the scenario of an aftermarket carb being placed on the engine and the OEM air cleaner system not fitting to it...but other than that, having those doesn't make a lot of sense after reading the aforementioned posts...What is your take on it?
You answered your own question. Those little rectangular filters are sitting on top of Weber carburetors and the mounting flange is rectangular, so the OEM housing won't work on them.
CSP is online now
post #20 of 37 Old 09-03-2010, 02:29 PM
indiandog
original 81 amc cold air intake, thanks to autozone
cj5- cold air intake 001.jpg   cj5- cold air intake 002.jpg   cj5- cold air intake 003.jpg
post #21 of 37 Old 09-03-2010, 02:52 PM
keith460
Jeep. There's Only One
keith460's Avatar
Yeah, you guys really bring up some good points. I didn't realize that the OEM air cleaner system was truly the original "CAI"...so to speak. Real good point on the placement of the filters in the engine compartment. Its funny how you tend to let the marketing of these products cloud your thinking and of what the product really is. Another question just kinda popped into my head after reading the posts too...if the OEM is such a good option to keep, why is it that you see a lot of carbs with little rectangular filters mounted directly on top, in a lot of the pictures in a lot of the posts on here? I can imagine the scenario of an aftermarket carb being placed on the engine and the OEM air cleaner system not fitting to it...but other than that, having those doesn't make a lot of sense after reading the aforementioned posts...What is your take on it?
The picture I posted shows the ever popular Weber 32/36 conversion that usually comes with the small rectangular air filter assembly. The same one is supplied with the Weber 38 DGES but a lot of people don't realize that an adapter also made by Weber can be purchased to adapt the factory OEM air cleaner assembly to the Weber carb like I have as shown here: Carbs Unlimited Weber Carburetor Conversion Kit
There are also other air cleaner adapters that can be bought as well as other air filter assemblies too and they can be found on this page: Accessories Page and this one: Air Cleaners for Weber Carburetors
It's amazing what can be found by doing a little research and Googling keywords.
1984 CJ-7 Renegade
keith460 is offline
post #22 of 37 Old 09-03-2010, 07:00 PM
fredrok
http://www.jeepforum.com/forum/f8/co...-mpfi-1089286/
If you don't have time to do it right, how will you ever find time to do it again?
fredrok is offline
post #23 of 37 Old 09-09-2010, 08:20 AM
bleoh
I just saw this. Looks interesting for the folks who have gone with MOPAR MPFI since it could also be useful for water crossing. But I wonder about noise inside (did I just really say that for a CJ!!!!).
Search Results - Quadratec
bleoh is offline
post #24 of 37 Old 09-09-2010, 12:25 PM
jeepwhore
Transdapt makes an adapter for those of us running an MC2100 to mate the stock air cleaner to the Motorcraft carbs. (provided the MC2100 has a 5-1/8" flange and the carter has a 2-5/8" flange like I think they do).
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #25 of 37 Old 09-09-2010, 12:42 PM
gojeepin
1983 CJ7
It's a bit pricy but if you're interested in a cold air system you can get this.
For the Weber crowd... you'll have to mount it on this adapter.
Here: K&N Plenums & Weber Adapter - Custom Plenum
I use the adapter for a traditional air cleaner but I could put the plenum, tube (or snorkle), and filter on at any time.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #26 of 37 Old 09-09-2010, 12:49 PM
CJay7
K&N has a few options to build your own.
EDIT: One of them was posted right above, guess I should have posted faster.
'85 CJ-7 - 258 bored .030 w/ mid level cam, 4.0 head, Clifford intake and header, Weber 38, TFI w/ MSD 6, Black Diamond 3" lift, Daystar 1/2" lift shackles, 33x12.5 Goodyear Duratracs with stock 3.31 gears.
CJay7 is offline
post #27 of 37 Old 09-09-2010, 01:22 PM
gojeepin
1983 CJ7
I may be old but I'm quick on the draw.
Here's another with a larger input (& less expensive... $93.99) from Spectre... you'll still need the carb adapter for the Weber (not for the Motorcraft).
I found it at Summit Racing (Plenum at Summit Racing) & JEGS (Plenum at JEGS).
gojeepin is offline
post #28 of 37 Old 09-10-2010, 06:38 AM
sgtbookie
Some guys use the bonnet off of an early 90s Cadillac, and they can be found cheap at local pull a parts. I picked one up for my MC2100 install, but havent gotten around to modifying it. With the spacer on the MC2100 the bonnet sits too high and rubs the hood on my CJ.
My MC 2100 air cleaner - Off-Road Forums & Discussion Groups
Pretty sure there is a user on this forums running the caddy bonnet too.
2005 LJ Rubicon Sahara #380
sgtbookie is offline
post #29 of 37 Old 09-12-2010, 12:12 PM Thread Starter
81CJUSMC
1981 CJ7
So, my questions seems to be becoming...Is the MC2100 a better carb? and why?
If it's that important to do on a Friday, it can wait until Monday...
81CJUSMC is offline
post #30 of 37 Old 09-13-2010, 08:40 AM
CSP
Is the MC2100 better than what, the stock carb?
Absolutely. There's a metric crap ton of info about them, but basically the MC2100 is less likely to have idle jet problems and runs well in off camber situations.
CSP is online now
The CJ thinks its cold gmakra Jeep CJ Forum 4 01-04-2010 06:32 PM
A question about 258 Intakes and Carb Upgrades 78CJFIVE Jeep CJ Forum 4 11-05-2009 07:39 PM
cold air intake JeffMcBusa Jeep CJ Forum 6 04-24-2009 04:14 AM
Cold Air CJhollic Jeep CJ Forum 14 10-26-2008 12:03 PM
258 intakes petey156 Jeep CJ Forum 5 11-21-2005 03:38 AM
