Why the spacers to lift my T-5? - JeepForum.com
post #1 of 9 Old 03-07-2013, 08:26 PM Thread Starter
kchadtho
1983 CJ7
I haven't had my CJ7 long before a clutch problem. When pulling the transmission, I found 1" tall spacers (hard plastic structured cylinders... not rubber) located between the stock transmission mount and the transmission itself. The skid plate is factory and is not dropped. The Jeep has a 4" leaf suspension lift and no body lift. While I certainly might not understand driveline geometry, common sense seems to say that lifting the tranny makes my drive shaft angle worse (and I already have some vibration). Then I thought that maybe the motor mounts are lifting the motor some?? I've never heard of that, but I did measure the rubber part of the motor mount... just a bit over 1-3/4" thick. Anyway, searches in this forum regarding spacers to lift a transmission didn't pan out. Any ideas? Thanks in advance for sharing your experience.
kchadtho is offline
post #2 of 9 Old 03-07-2013, 09:43 PM
jeepwhore
If you are thinking the transmission should be bolted directly to the skid plate, you're mistaken. Sounds like someone replaced the stock rubber transmission mount with a poly one. Got a picture of it? That will clear things up.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 9 Old 03-07-2013, 09:51 PM
jeepwhore
Just re-read your post. So the stock rubber mount and torque arm is still there and the spacers are between that and the tranny? Definitely wierd. Could be someone raised the tranny to give more clearance between the back of the valve cover and the firewall. But thats certainly an odd way to do it.
post #4 of 9 Old 03-08-2013, 07:40 AM Thread Starter
kchadtho
1983 CJ7
Your second read is correct... stock transmission mount and torque arm, but between that and the tranny are the 1" spacers. Other than possibly closing the gap between the valve cover and the firewall, wouldn't removing the spacers actually improve my drive shaft angle? My purpose for asking is mainly vibration related. Although the vibration isn't all that bad, if the spacers aren't helping me any, I'd just as soon toss them. I just don't have the confidence to do so without asking some more experienced guys.
kchadtho is offline
post #5 of 9 Old 03-08-2013, 08:39 AM
travisrda
never heard of having spacers there, usually if you add a lift then you need to drop the transmission to improve the driveline angle. What are the spacers shaped like? How many are there? if they are round maybe you could re-use them to put between your cross-member and the frame to drop the tranny more, that is if you are still having driveline vibration issues.
travisrda is offline
post #6 of 9 Old 03-08-2013, 09:53 AM
scrapman
The only reason I could think of to do that would be if the valve cover was hitting the fire wall causing problems. I have seen this happen when people drop their skid plate to help driveline vibrations, but never heard of anyone lifting the transmission.
Just a shot in the dark.
scrapman is offline
post #7 of 9 Old 03-08-2013, 10:12 AM
only in a jeep cj
Check to see if there is a one inch body lift. The po might have raised it the keep the shifter/ tub/ boot relationship like stock
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #8 of 9 Old 03-08-2013, 10:52 AM
shadoow
Is it possible the support plate is not in the correct position? Are the spacers located in a 'valley' area of the support plate - ie if the torque arm was over a high area of the support plate instead of a valley the spacers wouldn't be needed??
shadoow is offline
post #9 of 9 Old 03-08-2013, 04:49 PM Thread Starter
kchadtho
1983 CJ7
thanks everyone for weighing in...
On the question regarding a body lift, the bushings on top of the frame mounting pads are only about 3/4" tall. Just looking at pictures of body lift kits, I'd say my Jeep doesn't have a body lift.
Shadoow, you are probably onto something. I don't guess I know what the correct skid plate location is. But, definitely, of the three "steps" in the plate, it was mounted on the lowest (to the ground) step. Of the three bolt hole locations on each side of the skid plate, there were only two bolts installed on either side... and the third hole didn't really line up. So, does anyone know which "step" the transmission should be mounted on?
kchadtho is offline
driveline , lift , transmission mount
