Why So Weak?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Why So Weak??
Amsteel Blue Synthetic Winch line Free ShippingTravelling with Pets?Steering and more from Ruffstuff!
Unread 05-09-2006, 08:55 AM   #1
qwert98
Why So Weak??
I bought an 86 Cj7 with:
32" wheels
3 speed auto (1 yr old)
Straight 6 (4.2L)
195K, but runs well - no sputtering or hesitating
Weber carb (1 yr old)
Headers
and the timing, plugs (didn't check gap) and wires look good.
The problem is the jeep has no power. It top's out about 60 MPH, but even low end seems extremely sluggish.
Any ideas? I know the gearing could be off, but then I would sacrafice top end speed for low end power - and I don't even have that.
I need to drive on the highway to get to the trails!!!
qwert98 is offline   Reply With Quote
Unread 05-09-2006, 09:01 AM   #2
jeepskate
It's the gearing. You likely have the base stock gears which are 2.73's...barely adequate for moving the stock tires. With the towing package you get 3.31's which mine has/had (rear has been regeared, haven't had time to do the front yet) which are just barely adequate to handle 32's. I went to 35's and it could barely get out of it's own way which is probably about the performance that you're seeing. Prior to the 80's, stock was 3.54. You need to regear.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
http://www.jeepskate.net
jeepskate is offline   Reply With Quote
Unread 05-09-2006, 09:41 AM   #3
MR.CJ-7
I'll second that!
I had 3.54's stock in mine. They were fine with 30" tires and marginal with 33"s. That was with the V8 with headers, 2bbl motorcraft carb and a 3spd auto trans. I regeared to 4.56 and love it. I just made the switch from headers to manifolds for IM reasons and despite what everyone says about minimal losses between headers and manifolds, I lost a lot of power. Now I'm kind of wishing I would have gone to 4.88's.
Good luck to you!
Former CJ'er
MR.CJ-7 is offline   Reply With Quote
Unread 05-10-2006, 08:43 AM   #4
qwert98
Thanks for the replies.
I marked the drive shaft and tires, lifted up the rear end, and spun the tire tire one revolution. That turned the shaft ~4.5 times. That means my gears are near 4.5's.
If that's the case, does that mean that my gears are good for the 32" wheels?
I am going to hook up a tach to check the RPM's at 60mph - but is sounds like it's screaming.
Any other ideas???
Unread 05-10-2006, 02:32 PM   #5
MR.CJ-7
I tach about 3300 at highway speed. It hasn't hurt anything yet
Former CJ'er
Unread 05-10-2006, 03:02 PM   #6
CJ5_Fan
1980 CJ5
Any other ideas???
I would be surprised if you came stock with that gearing. You would be better off taking the code off the axel and looking it up to be sure of the gear ratio.
1980 CJ5 Renegade with 304 v8
Click HERE to check out my CJ5 restoration project page
CJ5_Fan is offline   Reply With Quote
Unread 05-10-2006, 04:44 PM   #7
MR.CJ-7
Maybe a previous owner swapped in 4.56s?
Former CJ'er
Unread 05-10-2006, 08:40 PM   #8
jakemary
1977 CJ7
pull the diff cover off. count the gears. its messy but it works no more wondering.
jakemary is offline   Reply With Quote
Unread 05-10-2006, 09:04 PM   #9
mr_frenchy
Have you done a compression test on the engine?
'75 CJ5, SOA, 36" buckshots, Warn 9000i upfront, 304 V8
In the Bible some where it says that if you sell your Jeep to buy a honda, you'll go to hell. It's somewhere in the back, near the maps.
mr_frenchy is offline   Reply With Quote
Unread 05-10-2006, 09:23 PM   #10
cage013
well with 2.73s and open diffs i could turn 4+times with onw tire rotation so
pull the cover and check
cage013 is offline   Reply With Quote
Unread 05-11-2006, 07:17 AM   #11
famicom21
i have an 86 cj7 w/ a manual 4 speed that had no low end torque whatsoever(and high end), for me it was the carb (a carter BDD - aka p.o.s.), i put a manual choke on to recover some low end torque back, but ultimately ended up switching to a motorcraft.
i would check and make sure your choke isnt sticking closed, that would make the engine sound gurgilie (???)
Yellow 86 CJ-7 Red 70 CJ-5
"Out on the road, out 'neath the stars, Feelin' the breeze, passin the cars."
famicom21 is offline   Reply With Quote
Unread 05-16-2006, 02:27 PM   #12
qwert98
The rear end has limited slip (or a locker). When I jack it up and spin one wheel, the other spins.
I am thinking htat it is 4.56 gears, since the engine screams at 60mph. I have not checked the compression, but the engine does smoke a litte and it eats a little oil esp. at high speeds.
I think I may regear it with 3.54 a little higher to get more high end. Anyone want to trade a Dana 30 front end with 4.56 gears for Dana 30 with 3.54's or close?
Unread 05-16-2006, 02:36 PM   #13
Hibbitz
If you have 4.56 gears and there isn't anything really wrong with your engine, you should have No problem getting right up to 60 mph.... you just won't go much faster than that. The best way to know what you dealing with is to count the teeth. This will save you from ordering parts/changing things based on what you think the gearing is.
KLH
Hibbitz is offline   Reply With Quote
Unread 05-16-2006, 06:31 PM   #14
thenubsterman
or he could just read the 2 numbers on the ring gear divided them out and it will give your the gear ratio
thenubsterman is offline   Reply With Quote
