Why does it take forever to start? - JeepForum.com
post #1 of 15 Old 04-14-2011, 05:27 AM Thread Starter
chatas1
1981 CJ7
When I go to start my CJ in the morning or when it hasn't run for a few hours it takes forever to start. I have to crank and crank and crank it over until it catches. When it's warm, no problems... I'm about to switch out the carb to a weber but I wanted to understand why before I switch it...
Thanks
chatas1 is offline
post #2 of 15 Old 04-14-2011, 05:55 AM
george29223
1978 CJ5
a TFI Ignition Upgrade will work wonders on cranking
george29223 is offline
post #3 of 15 Old 04-14-2011, 06:16 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Sounds like maybe the your fuel pump is letting the gas drain back instead of holding some in the line.
You carb is letting gas leak and you have to crank it for awhile to refill the bowl before it'll run.
Doesn't sound like an ignition issue.
Pacfanweb is offline
post #4 of 15 Old 04-14-2011, 06:25 AM
twoleos617
Pac,
fuel pump or filter?
twoleos617 is offline
post #5 of 15 Old 04-14-2011, 06:27 AM
4lowherewego
1979 CJ7
do u pump the gas 2-3x's before trying to crank??
79CJ7 360 .030 over, mc2100, T150, Dana20, Trak-Lock'd AMC20, 4" Skyjacker springs, 33" Boggers on aluminum American Racing rims.
4lowherewego is offline
post #6 of 15 Old 04-14-2011, 06:45 AM
MoC
Timing could be off.
MoC is offline
post #7 of 15 Old 04-14-2011, 07:02 AM
CJ Chet
Check your fuel filter. Make sure the outlet is at the 12:00 position. Had that problem with mine.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #8 of 15 Old 04-14-2011, 07:39 AM
Balvar24
1979 CJ7
Choke?
Balvar24 is offline
post #9 of 15 Old 04-14-2011, 08:49 AM
lanecj5
1980 CJ5
Ours did the same thing.......Did the mc2150 upgrade..Now;pump it twice and its cranked. Had a carter in it.
lanecj5 is offline
post #10 of 15 Old 04-14-2011, 05:58 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Originally Posted by twoleos617 View Post
Pac,
Either.
post #11 of 15 Old 04-14-2011, 08:01 PM Thread Starter
chatas1
1981 CJ7
I'm afraid to pump it more than once before I start it because I flooded it the first time I tried it. I'll check the fuel filter and the timing. Thanks.
chatas1 is offline
post #12 of 15 Old 04-14-2011, 08:19 PM
mcmud
1983 CJ8
Trouble on the cold start and not with the hot would be an indication, to me at least, that the choke setting is a bit too slack or the vacuum pull off diaphragm is in need of attention.
mcmud is offline
post #13 of 15 Old 04-14-2011, 09:07 PM
truckshop21
1981 CJ5
if you have a 4cly its the fuel filter in the carb that has a check valve probably went bad
truckshop21 is offline
post #14 of 15 Old 04-14-2011, 09:37 PM
jcbjeep
try new spark plugs
jcbjeep is offline
post #15 of 15 Old 04-14-2011, 10:45 PM
Mickey_D
It's fuel delivery. Check the choke first.
With the engine stone cold pull the air cleaner top off. Have someone step halfway down on gas pedal and release it while you're looking straight down the throat of the carb. You should see the choke plate open slightly and then drop closed. If it doesn't close, there's your problem.
Next, hold the choke plate open with a screwdriver or something (that won't fall in). Shine a flashlight down the throat and have someone push the pedal down. You should see a squirt of gas. If not, there's your problem.
BTW, most 2bbl and 4bbl carbs on the top of V-8's will take in excess of 10 pumps to flood. My little 4 cylinder takes 4 or 5 pumps to start cold. And mine's on a manual choke.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
Mickey_D is offline
Need alternator help been stuck forever jeepcj7304 Jeep CJ Forum 8 01-05-2011 06:29 AM
Good Start/Hard Start/No Start tigercreek Jeep CJ Forum 2 05-25-2010 07:48 AM
304 takes forever to get warm-sputters, stalls, etc. kg45777 Jeep CJ Forum 2 11-19-2009 04:00 PM
Engine will Idle forever but under load will shut off jamisonsq Jeep CJ Forum 10 11-02-2009 02:10 PM
do 258s last forever? jeepin'bo Jeep CJ Forum 8 03-05-2005 09:36 PM
