Why do I need cowl? - Page 3 - JeepForum.com
post #31 of 51 Old 10-31-2012, 09:53 PM Thread Starter
vinnyabs
1983 CJ7
Originally Posted by Crazyray2929
I put a scoop on mine...
Doesn't keep ALL the water out but doesn't let alot in.
Like the looks of that! What brand and where did you get it?
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #32 of 51 Old 10-31-2012, 10:32 PM
Crazyray2929
1981 CJ7
I think it was a Rugged Ridge...(sorry I have short term memory loss)
I gave about $25 on buyitnowbay...
It's ABS plastic not metal but was better than I expected...
Fit was perfect.
Crazyray2929 is offline
post #33 of 51 Old 10-31-2012, 11:46 PM
rixcj
rixcj's Avatar
1979 CJ5
Another reason to run a cowl is to draw in dry air in the winter otherwise the windows not heated by the defrosters tend to fog up after a little while. Otherwise you are recirculating moist air inside the cab and when the moist air hits the cold windows, the water will collect on the cold surface.
Does the air you speak of have to pass through the heater box to become dry air, or are you talking about just letting in some outside air through the passenger side lower vent?
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is online now
post #34 of 51 Old 10-31-2012, 11:46 PM
dunebum
1974 CJ5
I removed mine and built an aluminum one to replace it .so you dont need one .But i removed the winshield also to lose wiegh so you dont need one of those either.
dunebum is offline
post #35 of 51 Old 11-01-2012, 08:40 AM
rixcj
rixcj's Avatar
1979 CJ5
I take it that you've done the heater blower motor upgrade ...
Rich
rixcj is online now
post #36 of 51 Old 11-01-2012, 06:33 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Rich
Air outside is usually pretty dry in the winter.
Heating it dries it further.
John Strenk is offline
post #37 of 51 Old 11-01-2012, 06:49 PM
fourbtgait
1930 MK Patriot
Once the temperature drops below freezing, the air starts becoming drier, even to the point it can be to cold to snow. In Mintana I have seen ice on the roads disappear during the day when it is below zero. Just like your ice cubes shrink in a freezer.
fourbtgait is offline
post #38 of 51 Old 11-01-2012, 07:44 PM
NOCHEEPGAS
1980 CJ5
Well you definitely need a cowl! It gives your windshield a place to bolt to, and it nicely lines up the hood and fenders too. What you don't need is a cowl vent!
NOCHEEPGAS is offline
post #39 of 51 Old 11-02-2012, 12:09 AM
rixcj
rixcj's Avatar
1979 CJ5
John Strenk says...
"Another reason to run a cowl is to draw in dry air in the winter otherwise the windows not heated by the defrosters tend to fog up after a little while. Otherwise you are recirculating moist air inside the cab and when the moist air hits the cold windows, the water will collect on the cold surface."
Rich
So..if all I would need is some of the cold, dry winter air to help with the defrosters, could I just open a window, a little?
I'm just trying to cover all my bases without having to have a cowl vent cutout in the 'glass tub. There's not one there, now.
Rich
rixcj is online now
post #40 of 51 Old 11-03-2012, 02:03 AM Thread Starter
vinnyabs
1983 CJ7
Touché!
vinnyabs is offline
post #41 of 51 Old 11-03-2012, 04:27 AM
John Strenk
1976 CJ5
John Strenk says...
Rich
I've done that when I'm plowing snow, it does help when all the windows fog up. Even dry cold air seem to remove the the foggyness quicker than waiting for the whole car to warm up. But at higher speeds it tends to get a little uncomfortable.
I just realized I drive all my cars with the window cracked open a little. It just seems to stuffy for me if I don't maybe it's because I drove my drafty CJ for so long.
I had to modify my cowl vent when I converted over to a 84 Heater system. Did not enjoy it one bit becuase you have to be right on the money to get everything lined up. There are no flexable hoses to connect the cowl vent to the heater box. Fortunatly mistakes with fiberglass are easy to fix.
post #42 of 51 Old 11-03-2012, 10:17 AM
rixcj
rixcj's Avatar
1979 CJ5
Thanks, John...
I'm going to chance NOT putting in the cowl vent. I have rebuilt my heater box, with a Blazer blower motor, and that thing puts out some serious hot air. I think I'll be OK.
If not, I'll go onto "Plan B".
Rich
rixcj is online now
post #43 of 51 Old 01-30-2013, 10:24 AM Thread Starter
vinnyabs
1983 CJ7
A little cut n grind, prime n paint, and rtv and my leaky fresh air duct is healed!
vinnyabs is offline
post #44 of 51 Old 01-30-2013, 11:12 AM
John Strenk
1976 CJ5
Look nice.
It would of been cool if you put a hinge on it with a rubber seal and it could pop up when you need some fresh air ajnd closed it would keep the water out....
post #45 of 51 Old 01-30-2013, 11:50 AM
DYontheForum
1981 CJ7
Look nice.
It would be even cooler if it could be down with an electric servo so.
DYontheForum is offline
