Why do I need cowl? - JeepForum.com
post #1 of 51 Old 10-27-2012, 04:36 AM Thread Starter
vinnyabs
1983 CJ7
Why do I need cowl?
I live in fla and do not need heat or A/c. Not rubbing it it but if my cowl is just a water source is there any reason I shouldn't seal it up?
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #2 of 51 Old 10-27-2012, 05:51 AM
davbytrace
1979 CJ7
Yep. Remove the ductwork. Seal it up.
davbytrace is offline
post #3 of 51 Old 10-27-2012, 08:47 AM
only in a jeep cj
Or take that same time and energy and fix the leak..... Just saying
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #4 of 51 Old 10-27-2012, 09:06 AM
jurgen24
Easier said than done :-; After sealing in about 5 spots, I'm about 90% leak free.
jurgen24 is online now
post #5 of 51 Old 10-27-2012, 10:06 AM
Matt80cj
1980 CJ7
my fiberglass tub didn't come with a cowl vent. (PO didn't cut it in) I don't seem to have any trouble with it. Its not noticably hot in the cab and the heater works fine in the cold season.
Matt80cj is offline
post #6 of 51 Old 10-27-2012, 03:07 PM
rixcj
rixcj's Avatar
1979 CJ5
I'm glad to know this. I'm restoring a used 'glass tub, and the PO also didn't cut the vent hole in the cowl. I don't want to, either. I wasn't sure if it would affect the heat and defroster operations. I don't care about fresh air coming in the bottom right side (passenger's side) vent.
What else would be affected by NOT having that cutout?
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #7 of 51 Old 10-27-2012, 08:11 PM
jammer1
1979 CJ7
I sealed up mine so I can reheat the air in the cab in the winter. It works, but when it rains and theirs no fresh air coming in, the windows fog up. The cab also gets warm when you have the doors on when its raining. This winter, I'm going to be looking to make a vent to bring in cool air or check into a a/c unit. Sealing it up does keep you dry though.
jammer1 is offline
post #8 of 51 Old 10-27-2012, 10:00 PM Thread Starter
vinnyabs
1983 CJ7
With no top or doors, I get all the fresh air input possible. So then what or how did you guys use and lessons you learned from doin it?
vinnyabs is offline
post #9 of 51 Old 10-28-2012, 07:59 AM
jammer1
1979 CJ7
With the chevy blower and a windbreaker curtain I get nice and warm in winter. I just have a problem with the side windows and the windshield fogging up. I thought about running a air vent from the front grill, just never got around to it. It is nice having dry feet and no water inside and the heater works better in the winter.
jammer1 is offline
post #10 of 51 Old 10-28-2012, 10:17 AM
keith460
Jeep. There's Only One
keith460's Avatar
If you guys are getting wet feet, you need to seal the duct work better. Most leaks occur where the duct attaches to the cowl and that seal that use to be there is no longer available anywhere. Foam seal will not work either as you need to make it watertight. Use butyl rubber strips from 3M to seal the heater assembly to the cowl and also use it inside the duct work to seal the original seams where the factory assembled the pieces together. Most CJ's are close to being or are over 30 years old and need new weather stripping and seals that have otherwise dried out from exposure.
1984 CJ-7 Renegade
keith460 is online now
post #11 of 51 Old 10-28-2012, 10:27 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Keith,
Thank you for that explanation. I have a leak at my feet. I thought it was coming from the seal between the cowl and windshield, but replacing that seal didn't fix the problem.
The heater assembly and ductwork has never been out of my CJ. After reading your post, now I know where to look next.
Matt
Matt1981CJ7 is offline
post #12 of 51 Old 10-28-2012, 10:32 AM
Renegade82
1982 CJ7
Most folks don't need a cowl. They can get their milk and beef at the supermarket faster.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #13 of 51 Old 10-28-2012, 10:58 AM
keith460
keith460's Avatar
Originally Posted by Matt1981CJ7 View Post
Keith,
Matt
I can remember my wife's brand new 1984 CJ-7 having leaks every time it rained. Those A-holes at the dealer used clear calking to seal just about everywhere except where it was leaking. I think she took it back to them 3-4 times before I decided to take matters into my own hands. They must have used 3 tubes of silicone caulk all around the cowl, roll bar mounts on the floor, etc. I found the problem using a garden hose to spray water at the cowl opening in the tub. The factory assembly line workers forgot to put the seal on the duct work and after several more trips back to the dealer, they added it and then removed all the clear caulking they had used to remedy the problem.
It is especially important to make sure the sealant is around the screw holes and threads of the screws so water does not drip on your feet.
1984 CJ-7 Renegade
post #14 of 51 Old 10-28-2012, 05:27 PM
jammer1
1979 CJ7
Another problem you can have (with a fiberglass tub) is the part of the cowl between the windshield hinges where the windshield gasket sits is not always straight. If you drop the windshield and put a straight edge along the top, it can drop as much as a eight of a inch. Also the approx 2.5 inch width can have this by the defrost holes. Mine was one eighth of a inch off and would leak down the defrost and run down the dash. When I rebuilt the cj7, I redid that section to make it straight which stopped the leak. I found out about it from a tread on this form years ago.
jammer1 is offline
post #15 of 51 Old 10-28-2012, 06:48 PM
82JeepCJ7
1982 CJ7
Its a Jeep. They leak. Get over it.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
