#1 | |
why did my jeep catch fire
I was out wheeling in the sand pit tonight and decided to get a little crazy i cam up a hill and the front came down i little hard ok really hard with a stock jeep she bottomed out and the smoke rolled thinking it was just steam i decided to open the hood and the carb was on fire. i got the fire out. when i got home i took the carb off while doing that i got shocked i think it cam from the seloind that mounts on the side of the carb can that short out and do i really need it on a a stock 285 with a carter carb thanks
#2 |
GO ONE MORE!!
lose the carter carb, with any carb jolted like that you run a risk of breaking a mount or a casting, but you will find that if you replace the carter with a MC2100 series carb with the 1.08 jets, and bypass the computer your jeep will run loads better.
#3 |
What was I thinking
Well it's realy hard to get shocked with 12 volts. Try it, grab both post on your battery at the same time.
The only possible explination is that for some reason the solenoid was activated and in the process of removing it, it caused a series of arcs that you felt in your hand. However the solenoid should not be activated with the key off. That is unless you tried to remove the carb with the engine running. ![]() Are all your hoses connected on the carb? There are two vent hoses that carry away gas fumes from the bowl. If the hoses are disconnected then fuel could possibly splash out and catch on fire. The MC2100 is a great carb but it won't pass any visual emission inspection. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
