Whoosh! when removing the gas cap - Page 2 - JeepForum.com
post #16 of 21 Old 07-20-2013, 01:10 PM Thread Starter
adman02
1979 CJ7
Drove around a bit with evap connected and without. Got the "pssst" each time.
Here's my new theory. The TBI return system pressure is too high. Maybe caused by fuel pressure that's too high???
Or could it be something clogging the tank vents?
Or could it be the LCV or Rollover valve malfunctioning?
Any thoughts?
adman02 is offline
post #17 of 21 Old 07-20-2013, 02:27 PM
xnodesirex
1978 CJ7
Not to hijack this thread (sorry adman).
I have the same woosh when I change the remove the gas cap (78 304 CJ-7; team rush'd). I always thought it was normal - does this mean its not?
xnodesirex is offline
post #18 of 21 Old 07-20-2013, 05:49 PM Thread Starter
adman02
1979 CJ7
Perhaps a small whoosh is normal. I dunno. My original was pretty significant though.
adman02 is offline
post #19 of 21 Old 07-20-2013, 06:39 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Any thoughts?
It should still vent someplace.
If the pump puts pressure on one side, it has to drop the pressure on the other side.
It could be either valve. isconnect one at a time...
John Strenk is offline
post #20 of 21 Old 07-21-2013, 05:39 AM
thompsoj22
i would say you fixed it
i have also installed the newer evac canister. also had the purge line t'd to manifold vac and i dont think it was suffecient enough. i put it back with the pcv circuit and it works perfect. use a hard plastic vac hose from the pcv "T" to the canister and adapt it at both ends with fuel line. this will prevent the purge line from collapsing from the high vac at idle. your tank should be pressurized to an extent, this tells you that the fuel vapors are being held in the system and not released into the atmosphere. the fuel spewing back is a topped off or high enough fuel level in the tank to be partially into the filler hose. just another AMC design quirk.
thompsoj22 is offline
post #21 of 21 Old 07-27-2013, 03:54 AM
SJ85CJ7
Now my problem is the reverse, the fill neck on my 85 CJ7 was dimpled from all the years of having a nozzle hanging during refuel and the gas cap would not seat correctly so I fixed it now no more leaking gas when taking a corner fast. Now after starting if I shut down and try to restart it won't, it's like I'm not getting any fuel or I'm getting a vapor lock. I'm running the 4.2L I-6 with a Weber carb with the three port fuel filter (one in two out) no emissions equipment other then the Cat and charcoal canister, minimum vacuum lines. I'm not sure what is going on, I've had the tank down a few time and know that all the lines going to it are new and in the correct places.
85' CJ7, 258 I6, "Team Rush" Weber 38/MSD 6A, T-176 4-speed, twin-stick Dana 300, DANA 30 fore - AMC 20 aft with stock 2.73 gears, 31" tires, 8k winch, "Dirtworx" rear bumper/tire carrier. My Daily Drive, JustEmptyEveryPocket
SJ85CJ7 is offline
