The whole wiring harness. - Page 2 - JeepForum.com
post #16 of 18 Old 07-04-2010, 10:05 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by NewdRecon View Post
...Tomorrow and Sunday's project: make my own wiring harness for the entire Jeep
I'm not sure you can complete that in two days start to finish, but let us know how it's coming along!
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #17 of 18 Old 07-04-2010, 11:12 AM Thread Starter
NewdRiver_
Originally Posted by JeepHammer View Post
Yup, that's factory duct tape!
What are you trying to wire anyway?
Are you wanting to put the entire wiring harness back in, or just 'Critical' systems?
Will this be a 'Daily Driver'?
I'm wiring everything. The Jeep has had half it's electrical systems torn out and has cut wires and grounding issues everywhere thanks to the 350 and glass body. Plus I need to wire up all my new Autometers and dash switches.
It's easier to simply build a harness instead of tracing each issue. Plus I can add in things I want like a 60 amp circuit for an electric fan, headlights on relays, and wiring for additional lights.
Yup, it's going to be a daily driver for the most part. Needs to be bombproof.
Originally Posted by vmaxup
Go Painless. Mine was easy. You have allot of work ahead of you.
Where's the fun in buying a harness? I considered it but voted it down because they are about 5x the cost of materials I've spent so far and I'd have to cut it apart anyway because of the 350.
Yeah...but at least I got a start so far
All the wires are mapped, labeled, and have been removed from the fuseblock. Blades from the block are soaking in contact cleaner right now.
NewdRiver_ is offline
post #18 of 18 Old 07-04-2010, 04:22 PM
Mike Romain
The plugs and socket are all the same as GM uses in things like full sized vans and such that don't see weather. I got a harness from a van and used all the pigtail ends of the plugs (plug with 6" of wire, used solder and weatherproof heat shrink) to solder in for almost new plugs and sockets. They are easy to find at wreckers. Just a thought for you. That lasted me 10 years in the rust belt, then I went with a Centech harness because there was no copper left in the old one to solder to.
Mike
Mike Romain is offline
Wiring Harness by EZ 47redwillys Jeep CJ Forum 5 08-28-2009 10:41 PM
86 Cj No Wiring Harness???? BRS6482 Jeep CJ Forum 3 05-26-2009 09:06 AM
Wiring Harness ID chet44 Jeep CJ Forum 2 01-18-2009 09:12 AM
Wiring harness s.wetherald Jeep CJ Forum 9 03-19-2007 03:43 AM
Wiring Harness help jpnkavu Jeep CJ Forum 4 10-07-2006 09:40 AM
