Who is the Weber Tune Guru? - JeepForum.com
post #1 of 5 Old 07-21-2008, 08:44 PM Thread Starter
b.d.d.
1983 CJ8
I would like to do some tune work on this thing with the new cam and all, but know nothing about Webers. Yes, I got the Weber carb manual from Haynes, but it is not much help. All I have done is go from box to intake.
I have the PSI regulator installed and set at 3.5 psi. I'm having to use springs and all kinds of stuff to keep the carb at idle. Most of the screws are either screwed all the way in or all the way out. No matter what I do nothing seems to make a change. The carb itself never seems to kick in, runs on one brl at all times.
I need some help, step by step type instructions, something. 34 DGEC
83 CJ8
b.d.d. is offline
post #2 of 5 Old 07-21-2008, 08:48 PM
CJhollic
1980 CJ7
Here is the web site that has all the set up procedures.
http://www.redlineweber.com/html/Tec...f_contents.htm
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline
post #3 of 5 Old 07-22-2008, 01:04 AM
mcmud
1983 CJ8
Weber? Hardly!
But this link covers the 'thing' you have. I would suggest you send it back if you can and get a genuine Weber. The Haynes Weber Manual, nor the Webers Tunning Manual or any of the distributors or suppliers will participate in any manner with the remedies necessary with the 'morph' you have. This and other forums are crowded with prior post concerning 'The New Weber'.
I hate to be so negative. I'd help if I could but I can't.
You need a genuine guru or a Weber!
Here is the link for all the good it will do and Good Luck; http://www.racetep.com/dgec.html
mcmud is offline
post #4 of 5 Old 07-26-2008, 04:38 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
my best geuss would be a major air leak..probably in the base adaptor..Reset the carb to out of the box tuneing and check for leaks..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #5 of 5 Old 07-26-2008, 04:41 PM
WolfDawg
Yep....mcmud is right. This is the same carb I have and it's just an off-brand POS with Weber stickers on it....I hate mine. When I can afford to, I think I'm getting fuel injection...
WolfDawg is offline
weber 34\34 is not made by weber!!! stlouis400ex Jeep CJ Forum 22 02-26-2013 11:39 AM
WEBER 34 DGEC Carb TOO RICH??, Jets & Tune for Jeep 4.2 / 258 Fjguercio Jeep CJ Forum 55 05-13-2009 01:14 PM
Need AMC V-8 Guru jksull Jeep CJ Forum 3 01-31-2009 07:12 PM
Wiring Guru Needed Aggie99 Jeep CJ Forum 12 03-17-2008 08:05 PM
Backfire and weber tune help rb85cj7-82cj8 Jeep CJ Forum 4 03-02-2007 08:58 PM
