who sales a good fuel sending unit - JeepForum.com
post #1 of 35 Old 06-18-2013, 08:50 PM Thread Starter
bobbycj5
1
bobbycj5 is offline
post #2 of 35 Old 06-18-2013, 09:13 PM
dg6772
There is a company in the mid-west that will rebuild your's reasonably. I can't remember their name, but a simple search should put you in touch. They specialize in repairing sending units. A friend of mine used them to fix his sending unit for his 1975 Monza, since they are not available.
Dave in Muskegon
dg6772 is offline
post #3 of 35 Old 06-18-2013, 09:55 PM
WindKnot
1977 CJ7
Did you by chance test the gauge with a resistor? If you haven't you may want to try picking up some 10 ohm resistors from Radio Shack or some place similar, and then test the gauge from the back of the Jeep.
This isn't precise, but it's close. the idea here is to see if the gauge is at least moving using the existing wiring and the gauge.
A full tank equals 10 ohms.
1/2 tank equals 23 ohms
Empty equals 73 ohms.
20 & 70 ohms resistance will be close enough to watch the gauge needle move.
Ground out a 10 ohm resistor and touch it to the sender wire going to the gauge. You should have a gauge reading "full".
Now, string 2 resistors end to end (series) and re-test. You should get 1/2 full.
Same thing with 7 resistors, or whatever adding to approximately 70 ohms. You should get close to empty. You could also use a variable resistor and an ohm meter to set it. You get the idea... imitate a working sender to test the gauge.
The cool thing is you can do this to the temp gauge as well and you can do it without removing the gauges from the dash
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #4 of 35 Old 06-18-2013, 10:15 PM Thread Starter
bobbycj5
1
bobbycj5 is offline
post #5 of 35 Old 06-18-2013, 10:51 PM Thread Starter
bobbycj5
1
bobbycj5 is offline
post #6 of 35 Old 06-19-2013, 05:54 AM
PROJECT 23
Who sells.........
PROJECT 23 is offline
post #7 of 35 Old 06-19-2013, 06:31 AM
thompsoj22
check out there web site
Originally Posted by PROJECT 23 View Post
Who sells.........
my vent valves and grommets are on the way. i thought i would never find them.
http://www.mtscompany.com/miscjeep.htm
thompsoj22 is offline
post #8 of 35 Old 06-19-2013, 12:12 PM Thread Starter
bobbycj5
1
bobbycj5 is offline
post #9 of 35 Old 06-19-2013, 12:14 PM
PROJECT 23
Any time......
post #10 of 35 Old 06-19-2013, 01:51 PM
WindKnot
1977 CJ7
WindKnot is offline
post #11 of 35 Old 06-19-2013, 03:17 PM
hp_lovecraft
1981 CJ5
Originally Posted by bobbycj5 View Post
the grammer lessons realy helpful site
Grammar Nazis get added to the "ignore list" for me. It is one of those things, along with the "use the search" crowd that really reflects the quality of the forum.
But for the original question, I had a couple Omix senders die on me, so I bought a Spectre sender last year, and its still working great. It is a different design that the Omix and Crown that you usually see.
hp_lovecraft is offline
post #12 of 35 Old 06-19-2013, 03:37 PM
CSP
That's too bad. The grammar Nazis are the ones who pay attention to details and very likely to have correct information when there's conflicting information given on a subject.
CSP is offline
post #13 of 35 Old 06-19-2013, 03:51 PM
PROJECT 23
I guess the quality of the forum is going down the tubes then. Anyways, I think it actually improves the quality since users won't sound like a bunch of uneducated Americans.
Also using the word Nazi is just plain ignorant. Then again, I'm not sure what part of the sticks you're from so it might be a commonly used word.
BTW, I'm saleing a set of mesh headlight and turn signal covers. PM me if you be interested dog...... Word!!!!
post #14 of 35 Old 06-19-2013, 08:11 PM Thread Starter
bobbycj5
1
bobbycj5 is offline
post #15 of 35 Old 06-19-2013, 08:16 PM
WindKnot
1977 CJ7
Setting all that aside, how is the trouble shooting coming along?
WindKnot is offline
