who is running lockers? - Page 2 - JeepForum.com
post #16 of 57 Old 02-27-2013, 08:52 AM Thread Starter
big_o_tom
1978 CJ7
I have found it best to leave the both hubs locked in the snow, with one hub locked it wants to pull eractically to the side thats locked. Ive talked to few guys are into rock crawling and dont like the detroits at all because they will dissengage at times. They said that they run spools or "lincoln lockers". One of the fellas even drove on the street some with a spooled rear end, he sad it wasnt that much different than a detroit on the street. I guess if I get a selectable for the front it will be an ox because theirs know one around here that can install the other kinds.
big_o_tom is offline
post #17 of 57 Old 02-27-2013, 10:44 AM
60scrambler
1982 CJ8
PowerTrax front and rear. Dana 30 up front, AMC 20 rear. No issues.
60scrambler is offline
post #18 of 57 Old 02-27-2013, 12:10 PM
Frenimy
1981 CJ7
Same as 60scrambler and I must say that they are very impressive offroad but do give a few clunks when turning on the road but no real issues.
1981 CJ7 I6 258, NP435, Dana 300 Twin Sticks, AMC 20 & Dana 30 with Lockers, On board air, 33" X 12.50" tires
Frenimy is offline
post #19 of 57 Old 02-27-2013, 04:29 PM
CSP
I've been running ARBs since 1998. I have not had one problem with airlines leaking, solenoids failing (I use a manual air switch rather than electric solenoids), or any other problems with them at all. My on-board air is based on a York compressor, which is also bulletproof.
My CJ5 has an ARB in the front axle and the rear has a spool. I'm currently considering a Detroit to replace the spool. It's off-road only, except when we go to Moab we will drive into/around town. Prior to the current suspension/drivetrain setup I had an ARB in the rear axle and a Truetrac in front. I loved the combination. I had another CJ5 a few years ago with ARBs front and rear.
CSP is offline
post #20 of 57 Old 02-27-2013, 04:33 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Have ARB front and rear. In over seven years haven't been stuck once in the garage:
"In the end...It's all Hack."
HackFabrication is offline
post #21 of 57 Old 02-27-2013, 04:33 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
CSP,
I'm glad you finally chimed in on this one.
Any thoughts on the Ox selectable? I've read very few negatives about it. I like the idea of a mechanically operated cable to engage it. I think you can also buy a screw in tool that will engage/disengage it, if the cable breaks.
Matt
Matt1981CJ7 is offline
post #22 of 57 Old 02-27-2013, 05:50 PM
kjonesie
1983 CJ7
Auburn Ected Max front and rear with Dana 44's front and rear. They lock up tight without the noise of a compressor, leaking hoses and bad O rings
kjonesie is offline
post #23 of 57 Old 02-27-2013, 06:25 PM
nshefbuch
1982 CJ7
ARB for the win.
Plain and simple it's stronger than any electric ones on the market. No cable issues like OX either. The electric vs air is the old debate and the locker itself is designed better than electric ones. Electric takes up to 180 degree spin of it to actually engage and a ARB takes less than half that. This alone is a big enough advantage for me. My other concern is the electric lockers have a huge electromagnet in their and once activated I feel like metal shavings will all attract to itself. Maybe it's no concern but it bothers me.
I've been churning through tons of mud and never had an issue with the air line. My OBA kit is Viair which I've setup to run the locker and air tools. I'm running a front locker only and once money permits my 14 bolt will get one as well. It doesn't take much air to engage and keep it operating for the ARB. My 2.5 gallon tank can turn on and off my locker like 20 times before it needs to replenish. Probably even more but I haven't counted.
I went with ARB and didn't buy the air kit till later. I ran it as a open diff for months before adding my air kit. Glad i did and no regrets. All this nonsense of O-ring issues I haven't seen or heard much of in years. In their early days yes it was a concern but if you look at all the hardcore guys on 50+" tires, they are welded, ARB, or Detroit. None I've seen use electric.
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #24 of 57 Old 02-27-2013, 06:46 PM
roadhog304
1973 CJ5
I am running a Detroit in the rear and a trutrac in the front. You have to pay attention with the Detroit in the rear as mine likes to torque steer if I get on it really hard but other than that i have had no problems. I can handle the driving quirks for the trade off in reliability and bulletproofness it offers.
1973 Jeep CJ5 Amc powered resto-mod
1976 Jeep CJ7 GM powered future 1 ton crawler
roadhog304 is offline
post #25 of 57 Old 02-27-2013, 06:55 PM
kjonesie
1983 CJ7
Originally Posted by nshefbuch View Post
ARB for the win.
Dude, chill out. This is my experience with ARB's. I don't have, and never plan on running 50" tires. The Auburn is also a limited slip when not engaged. If you are concerned about metal shavings being attracted to the magnet, then maybe something is wrong with your setup.
kjonesie is offline
post #26 of 57 Old 02-27-2013, 07:03 PM
Matt1981CJ7
1981 CJ7
ARB for the win.
Exactly what "cable issues" with the Ox are you talking about?
Can you point to other reviews with the same issues?
Thanks,
Matt
post #27 of 57 Old 02-27-2013, 07:10 PM
zillla
1930 VJ
I have nothing agaihnst ARB's but as I stated the four I have been around all leaked, a bit and the compressor kept coming on. Maybe thats normal I don't know.. I wanted selectable in the rear. My choices were OX, ARB and electric. ARB seemed to cost more and depended on a compressor. Electric has too many small parts. OX seems pretty bullet proof to me.. You do have to get the cable adjusted correctly but that's a one time deal.. Detroit: who can argue with success..
All have pros and cons, to me it's a matter of personal preference..
Pull my finger
zillla is offline
post #28 of 57 Old 02-27-2013, 07:19 PM
zillla
1930 VJ
Thanks,
Matt
Matt the cable issue I had wasn't really a cable problem, but an adjustment problem. The original the OX locker cable was in direct contact with the lever so to speak. As you engaged the locker you pushed the lever forward and kept pressure on it. You could feel it engage and the lever moved forward to the lock position.
It was later design [as it is today] modified so there was a spring in there keeping pressure on the cable. You moved the lever to the lock position and the spring kept tension on the cable. It still locked, you just didn't have to keep pressure on the lever as the spring did that. On mine the cable twists around under the CJ5, and mine eventually stopped engaging, because the spring couldn't push it enough. OX offered to build me a shorter cable, but the tech also recomended that I remove the spring and reverse the collar at the lever and re-adjust. End of problem.. Mine now engages like the original and I can feel when it engages.. Clear as mud e'h?
Pull my finger
zillla is offline
post #29 of 57 Old 02-27-2013, 07:22 PM
nshefbuch
1982 CJ7
That's well said.
The local guys around here with OX all have issues with the cable. They claim when in a tight spot and needing to engage it the cable fights them and they have a hard time engaging. This is why I stayed away from it. These guys with them I respect their opinion on it and when you ask them if you could do it again, they all say I'd go with ARB.
Like mentioned its going to be personal preference. Yes ARB is the most expensive and their is no arguing that.
post #30 of 57 Old 02-27-2013, 07:25 PM
zillla
1930 VJ
Hmmm. I engage mine when offroad and leave it.. Unlock when I get back to pavement..
Pull my finger
zillla is offline
