Who carries floor plugs? - JeepForum.com
post #1 of 7 Old 01-27-2010, 10:42 AM Thread Starter
atomicflatulenc
I need to put some drain holes in my floor and I would like to find plugs that will keep things sealed up until I need to drain. I usually hose out the inside floor to get rid of mud and sand, but the holes that are there are too small.
Does anyone have any that work well?
I was thinking of using the rubber things that I used to use when I worked on pools. The things with the wing nuts. I was concerned that these would get kicked around all the time.
I'd like to find something like the original plugs that are flush with the floor.
'85 CJ7, 258 4.2 Howell TBI, NP435, twin sticked Dana300, 4.56 Yukon chromoly: Rear20-extra thick tubes, shaved,trussed,discbrakes,ARB: Front30- flipped tierod,Detroit EZ locker, warn hubs: 3.5" BDS YJ springs and booster, 35" Trxus M/T's, rhino'd, full roll cage, borgenson steering shaft, big daddy steering box bracket...Unknown OIL Leak(working on it...)
FOR SALE $6000
atomicflatulenc is offline
post #2 of 7 Old 01-27-2010, 10:49 AM
mvigo
mvigo's Avatar
I believe the holes are 1" and I have bought several of the plastic hole plugs at the local hardware store. They snap in place, and if they break you can always buy more as they are inexpensive. they look like this:
Grainger.com
hope that helps
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #3 of 7 Old 01-27-2010, 10:50 AM
Curt Reinhardt
1978 CJ5
Curt Reinhardt is offline
post #4 of 7 Old 01-27-2010, 11:28 AM
JoonHoss
2011 JK Wrangler
Originally Posted by Curt Reinhardt View Post
I bought those exact ones from Morris- they worked great
they are a different (and correct) design than the ones from Grainger and most Hardware type stores
Hoss
"three gallons of low lead; two hot dogs and a strawberry soda..."
JoonHoss is offline
post #5 of 7 Old 01-27-2010, 07:15 PM
mnCJ7guy
1980 CJ7
I bought some from ebay, for 6.95 shipped for 15 plugs. I have not installed them yet though
________________________________________________
1980 CJ7
151 4 Cylinder with a SR4
1990 YJ Islander
4.2L,Auto
mnCJ7guy is offline
post #6 of 7 Old 01-27-2010, 07:29 PM
Viencent
1982 CJ7
same as mnCJ&guy, got them from ebay and they went right in, work great sofar
Viencent is offline
post #7 of 7 Old 01-28-2010, 12:21 PM Thread Starter
atomicflatulenc
Nice. I'll have to use ebay next time. 4wd.com had them.
FOR SALE $6000
What to use for floor pan drain plugs with Linex, Rhino-line, bedliner, etc 10129 Jeep CJ Forum 4 09-20-2009 07:50 PM
Large floor plugs Fuzz21 Jeep CJ Forum 2 03-26-2007 02:30 PM
Floor pan drain hole plugs AggieCJ Jeep CJ Forum 7 12-26-2006 07:55 AM
floor plugs beachcruzr Jeep CJ Forum 1 07-12-2004 01:15 AM
Floor Plugs ?? Where ? Guy Hollister Jeep CJ Forum 6 12-17-2002 10:44 AM
