Whitco top & hard doors - how do I make them work togther? - JeepForum.com
post #1 of 8 Old 12-17-2012, 11:00 PM Thread Starter
twoscooterz
I have the original Whitco top. I want to use my hard doors but the plastic windshield/door seal that supports the horizontal section above the door gets in the way - door won't shut. Has anyone figured out how to make this combo work?
'86 CJ7 Laredo, 258, Weber 38, DUI, T5 w/Hurst shifter, 4.56 Dana 30, AMC 20, Detroit TruTrac, Moser axles & Blue Torch truss, Dana 300, stock YJ springs SUA, 33" MTR's, Poison Spyder sliders, NewGen tank cover, Warn 9.5ti w/synthetic rope
twoscooterz is offline
post #2 of 8 Old 12-22-2012, 10:31 AM Thread Starter
twoscooterz
Really, nobody has ever run into this issue and come up with a solution? I am thinking about buying a set of door seals and modifying them. Anyone tried that?
post #3 of 8 Old 12-22-2012, 12:51 PM
Bobs85Reny
Here is what i did. I modified mine and now i don't even have to take them off with the hardtop
image-3519496335.jpg   image-2911866167.jpg   image-1783871391.jpg   image-83691885.jpg   image-3838307349.jpg
Told my girl I just had to forget her, Rather buy me a new cartburettor,
So she made tracks sayin' ths is the end now, Cars don't talk back they're just four wheeled friends now
"Queen"
Bobs85Reny is online now
post #4 of 8 Old 12-22-2012, 01:45 PM
Bobs85Reny
I also had to reverse the vertical bars that are behind the door frame and bend them a little bit.
I also found I can run them without the vertical bars. its not as important if you don't run the soft doors. I just let the top bar rest on the door frame.
My next challenge this year is I just picked up a set of yj half doors. I don't have any uppers yet so I need to figure out the best solution for the whitco top.
"Queen"
post #5 of 8 Old 10-22-2013, 10:02 AM
ChrisEaton82
1982 CJ7
Hello Bobs85Reny,
can you explain what you did in text, i cannot see in the photos what it was you did....
thanks!
ChrisEaton82 is offline
post #6 of 8 Old 10-22-2013, 11:22 AM
keith460
Jeep. There's Only One
keith460's Avatar
You need to have a Whitco top that was designed to use with the Hard doors. It has special hardware for supports and it is cut unique for the hard doors.
My CJ-7 came with this setup from the factory.
1984 CJ-7 Renegade
keith460 is offline
post #7 of 8 Old 10-22-2013, 12:30 PM
ChrisEaton82
1982 CJ7
rough rider
so it looks to me that the rods over the doors are up higher due to a longer vertical rod (with a boomerang shape brace) and the receptacle on the windshield must be a small one with just a "cup" for the rod?
Is the canvas the same? in other words if I came up with or made new rods could I use one of my existing tops?
thanks!
post #8 of 8 Old 10-22-2013, 01:51 PM
keith460
keith460's Avatar
The top horizontal rods are square tubing and is separate from the vertical square tubing that has a plate bolted to it for the top material to snap onto.
1984 CJ-7 Renegade
keith460 is offline
