Whistle noise from engine? - JeepForum.com
post #1 of 6 Old 03-10-2013, 06:54 PM Thread Starter
FamousJerry
2014 JK Wrangler
Well i was driving home and my temp went up and i pulled over and thought i saw fluid coming from the water pump shaft. I could wiggle it a lot and it seemed to make it worse when i did. So i get a new pump gasket and clean the surface really really good use some grey RTV finger tighten it to let it set. then torque to specks about 45min later, let it sit over night before filling back up with 50/50.
I start it up let it warm up and i hear a whistle or almost sound like an electronic warning noise. Then after a while i see coolant leaking from the general area of my water pump
Any ideas what may cause this noise and if i could have cracked a block or something during the minimal time my temp went up ? and not far at all, i saw steam well before my temp gauge even moved.
May have to start the engine swap sooner that i had anticipated.
FamousJerry is offline
post #2 of 6 Old 03-10-2013, 07:07 PM
roboto65
1976 CJ5
I would have to say that it is time for a new Water pump the bearing has gone and there is usually a weep hole and that is the first indication the pump is going bad the whistle you are hearing is probably the bearing howling.
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
post #3 of 6 Old 03-10-2013, 07:24 PM Thread Starter
FamousJerry
2014 JK Wrangler
i just put in a new one and was testing it
post #4 of 6 Old 03-10-2013, 07:27 PM Thread Starter
FamousJerry
2014 JK Wrangler
ugh sounds like im getting another one from the store GRRRRRRR
post #5 of 6 Old 03-10-2013, 07:28 PM
roboto65
1976 CJ5
Not the first time I have heard of new parts being bad sorry.
roboto65 is offline
post #6 of 6 Old 03-10-2013, 07:59 PM Thread Starter
FamousJerry
2014 JK Wrangler
Wouldn't be so bad if it wasn't such a pain in the butt to change, ugh
