Where to start!? - JeepForum.com
post #1 of 8 Old 03-23-2007, 10:14 PM Thread Starter
sturoe
Where to start!?
I just got a 66 cj5 thats been kept in an airplane hangar, but hasnt been run in a while. It has the dauntess engine in it. I am curious to know where the heck to start on it. My first goal is to get it rolling with brakes and steering and an engine that runs stable. This is a big project for me, becasue im new to this. The only vehicles i have experience with are diesels, so i dont know where to start on this engine.
I want to start out somewhat minimalistic, as i am on a student budget.
any help is appreciated
stu
sturoe is offline
post #2 of 8 Old 03-23-2007, 10:58 PM
CGrugger
CGrugger's Avatar
What are your plans for it, rock crawler, dd, etc??
2005 TJ X: 2" RE spacer lift, 32"x11.5" tires, 1.25" Zone body lift, Curry Antirock sway bar.
CGrugger is offline
post #3 of 8 Old 03-23-2007, 11:16 PM
John N
1981 CJ8
Those engines are as close to bulletproof as almost any engine can be. 2 things to do to it are to replace the original timing chain and gears (they are/were nylon or plastic gears and crumble with age/use); the other is to clean out the oil pan.
Where in Va.?
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #4 of 8 Old 03-24-2007, 06:47 AM
jeepin in maine
change all the fluids,plugs,wires,cap,rotor,filters.unhook the chassis fuel line from the fuel pump,run a piece of new fuel hose from the pump to a gas can,and fire her up on FRESH gas.once it runs satisafactorily i'd then move on to cleaning the fuel tank,straigtening out the brakes(get that ancient brake fluid outta there),and going thru the front end.then you can start upgrading.get a solid running and driving base before you start.if you start upgrading before that and run into problems you won't know if its something you did or if its something that already existed.
jeepin in maine is offline
post #5 of 8 Old 03-24-2007, 02:18 PM Thread Starter
sturoe
thats exactly what i wanted to do, just getting running straight first. I will just be using this for recreational muddin and on the beach. Nothing real serious, just a fun toy to play with. What about steering knuckles, iv heard that this may be something that is likely to need replacing.
sturoe is offline
post #6 of 8 Old 03-24-2007, 02:20 PM Thread Starter
sturoe
Where in Va.?
Im in winchester VA btw.
sturoe is offline
post #7 of 8 Old 03-24-2007, 02:23 PM
nichols077
woah...im in winchester also haha you said your a student. are you going to su?
nichols077 is offline
post #8 of 8 Old 03-24-2007, 02:35 PM Thread Starter
sturoe
Haha not quite, maybe in a few years. I acctually go to Sherando HS-thats pretty cool though
sturoe is offline
No Key to Start illinicj Jeep CJ Forum 6 10-08-2009 06:54 PM
So where do you start. . . jpd1899 Jeep CJ Forum 17 01-20-2009 01:44 AM
My ignition is being stubborn, engine doesn't start in "start" position scrible Jeep CJ Forum 6 10-04-2007 11:04 AM
Where to start? luvdemCJ's Jeep CJ Forum 2 11-07-2005 11:10 AM
Won't start bigmike0601 Jeep CJ Forum 9 11-04-2004 04:26 PM
