where should i put my Engine Ground - JeepForum.com
post #1 of 3 Old 05-03-2014, 07:15 AM Thread Starter
garusher
1979 CJ5
HI,
I'm doing the jeep hammer battery to starter, alternator upgrade.
that write up does not state where i should put an engine to frame Ground or if i need one.
Should i go off the new starter ground to the frame? or just off some bolt on the motor to the frame?
Should i ground the alloy heads also? maybe a 10 gauge from my grounding post to the first head and daisy chain to the second head?
Thanks
Gary
garusher is offline
post #2 of 3 Old 05-03-2014, 07:39 AM
1949er
Factory is from block motor mount bolt to frame mount also run one from block to body
1949er is offline
post #3 of 3 Old 05-03-2014, 07:43 AM
Mike Romain
The stock one on mine is a heavy mesh strap that goes from one side of the drivers side engine mount to the other. The engine to body one is a strap from a head bolt to the firewall. Mesh straps are used due to the vibration and movement. Copper cables can work harden over time from the engine movement and fray apart.
Mike
Mike Romain is offline
