Where to get Brake Line Clips? - JeepForum.com
post #1 of 8 Old 09-28-2010, 05:54 PM Thread Starter
GuacaTex
1981 CJ7
Had to replace a couple of sections of brake lines because they corroded out. They were the left & right lines between the tee fitting on the diff to the rear cylinders.
The new lines don't have the armor (spring like winding around the OD of the tube). Now the little bolted metal clips that secure the lines are either too large (because of missing armor wrap) or are corroded out.
Where can I get replacements?
The guy at the parts counter looked at me cross eyed when I asked. I thought about just making some out of sheet metal, but I don't want to put that much effort into it. Thought about using zip ties as well, but those prabably wouldn't hold up too long.
What have you brake line plumbers done?
Thanks,
GuacaTex is offline
post #2 of 8 Old 09-28-2010, 06:12 PM
Hybrid Jeep
1976 CJ5
These things are great.. they are called P Clamps.. or P Clips...
You can get them at Lowes in the bolt row.. A good one to get is the 3/8". I used a LOT of these in my rebuild...
Hybrid Jeep is offline
post #3 of 8 Old 09-28-2010, 06:18 PM Thread Starter
GuacaTex
1981 CJ7
oooh. Looks perfect.
I'll check it out. Hope they come in 1/4" (size of tubing).
Thanks,
GuacaTex is offline
post #4 of 8 Old 09-28-2010, 06:43 PM Thread Starter
GuacaTex
1981 CJ7
Ha, Hybrid got me go'en now.
4WD has a brake line clip set for ~ $14 (ouch).
Googled P-clip and found similar clips that are electrical loom clips with vinyl coating. Bag of 10 - 1/4" clips is $2.25 Linkie
GuacaTex is offline
post #5 of 8 Old 09-28-2010, 06:52 PM
paraman72
Those rubber wire loom holders are not cheap either try $7 for a pack of 3...
I need them too but would like to find a place cheaper to get them.
85 CJ7 Build in progress, 258 with T-5 and dana 300.
Fiberglass tub Raptor lined interior, rustoleum lined the underside. Modified family roll bar from fender mounted rollbar. Full tie ins to the frame soon to come.
paraman72 is offline
post #6 of 8 Old 09-28-2010, 07:43 PM
243
1978 FSJ Cherokee
Totally Stainless has SS clips, singles are 1.65 for 5/16 and doubles are 2.29.
Dave's 78 Build
243 is online now
post #7 of 8 Old 09-29-2010, 08:54 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I used all plastic ones. waiting to see how long they last.
John Strenk is offline
post #8 of 8 Old 09-30-2010, 05:05 PM Thread Starter
GuacaTex
1981 CJ7
Picked up some of the metal one with the rubber at Lowe's today. $1.27 for package of two clips. They also had some in nylon. Bag of the nylon ones (at least a 1/2 doz) was $1.27 as well. They only had white nylon, but I think I've see black nylon as well.
They were in the fastener isle, in the drawers for "hard to find". They also had a reasonable assortment of other "auto chassis" fasteners that I didn't realize a hardware store would stock.
I lernt som'n.
GuacaTex is offline
CJ Fuel / Brake line clips / retainers jmn444 Jeep CJ Forum 3 10-07-2009 06:37 AM
E-brake retaining clips - WHERE DO I FIND EM?? imtheant Jeep CJ Forum 2 06-09-2009 06:07 AM
pictures of stock amc 20 brake line clips spk454 Jeep CJ Forum 3 07-01-2008 05:01 PM
Dumb Brake Line and Fuel Line Question GroundUpCJ7 Jeep CJ Forum 3 04-02-2007 06:01 PM
parking brake retaining clips T-$$ Jeep CJ Forum 5 06-21-2006 07:27 PM
