Where to find door strap bracket (on tub) - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Where to find door strap bracket (on tub)
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 05-16-2011, 09:09 PM   #1
mtnbikeidaho
1982 CJ7
Hi. I recently bought some hard half doors for my 1982 CJ7... Seems I am missing the "Z" shaped bracket that goes inside the tub on the lower door hinge. It's the bracket that the pin bolts to in order to hold the door catch strap (if that makes any sense).
Where can I find these? No "u-pull" junkyards around here have any Jeeps older than early 2000's. Any ideas? Can't seem to find any new. I saw a thread where someone manufactured some from angle iron, but I suck at welding...
mtnbikeidaho is offline   Reply With Quote Quick reply to this message
Unread 05-16-2011, 09:31 PM   #2
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Is this what you're looking for:
http://www.jeep4x4center.com/product...umber=WAR90800
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline   Reply With Quote Quick reply to this message
Unread 05-16-2011, 09:42 PM   #3
mtnbikeidaho
1982 CJ7
Nope.... Got the door mounts. I need the other end that bolts to the tub on the back side of the hinge plate. The "strap pin" is readily available, too. http://www.quadratec.com/products/13029_400.htm
But not the bracket the pins bolt to.
Unread 05-16-2011, 09:50 PM   #4
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Oh, the tub side. I'll see if I have any tomorrow.
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
Unread 05-16-2011, 09:58 PM   #5
mtnbikeidaho
1982 CJ7
Much appreciated!!
Unread 05-16-2011, 10:21 PM   #6
mtnbikeidaho
1982 CJ7
In order to help future lurkers... If you're good at fabrication, I found this link as well: http://www.jeepforum.com/forum/f8/wh...ml#post5669583
And I stole this pic from 243:
Pretty good looking...
Unread 05-16-2011, 10:35 PM   #7
BagusJeep
1981 CJ7
Looks like an excellent piece of fabrication.
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread 05-23-2011, 08:44 AM   #8
mtnbikeidaho
1982 CJ7
So, in order to bring a resolution to this in case anyone ever reads it...I ended up getting a set off of ebay. The next best option would be to fab your own. Good luck!
Unread 05-23-2011, 09:04 AM   #9
waterdowg
Perhaps, Home Depot or Lowes. They sell a cleat for tying off rope. They are about the double sided so you could cut one end off.
waterdowg is online now   Reply With Quote Quick reply to this message
Unread 05-23-2011, 02:21 PM   #10
AdamH07
1981 CJ8
Were they orange by chance in the pics? If so, I was bidding on them too! Oh well, off to find another set.
'81 CJ8 Scrambler
'82 CJ8 Scrambler
'14 JKU Rubicon
'12 WK2 Overland HEMI 4x4
AdamH07 is offline   Reply With Quote Quick reply to this message
Unread 05-24-2011, 12:59 PM   #11
mtnbikeidaho
1982 CJ7
Not talking about the pins. See the photos.
Unread 05-24-2011, 01:01 PM   #12
mtnbikeidaho
1982 CJ7
Actually, no. They were the ones in the photo I posted earlier (I stole the pic off of ebay before I bid on them.)
Get this...I got them for 5 bucks plus shipping. $11 !!!
Unread 05-24-2011, 02:02 PM   #13
hp_lovecraft
1981 CJ5
Is that how you attach them? I had no idea. I ordered the same strap kit linked above. When it arrived, I could not figure out how to attach them, so I just drilled a couple holes:
I kinda like my solution better. Looking at the strap brackets above... they look like they could give someone a nasty cut if you hit a serious pot hole!
hp_lovecraft is offline   Reply With Quote Quick reply to this message
Unread 05-28-2011, 06:03 PM   #14
Blue84JeepCJ7
I need a set too. Anyone got a spare set?
84 CJ-7
Chevy 350, Mild Cam. (325hp)
Summit (600 CFM) Carb.
1987 TH700R4 "K" Case
32x11.5x15 Cooper ATs
3" Body Lift
Be-Cool Radiator
Black Magic 175 Cooling Fan
Blue Jeep Club Member #212
Blue84JeepCJ7 is offline   Reply With Quote Quick reply to this message
