the title pretty much says it all, in the hayes manual it shows it between the rear pinion bearing(closest to the splines) and the oui seal , but in a you tube video i just watched it shows it in front of the front pinion bearing (closest to the teeth)
Not all of them do. You'll see them in high pinion axles almost exclusively, but low pinion is a crapshoot as to if there is one or not.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
