Where do ya'll put a Holley fuel regulator for a Weber? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Where do ya'll put a Holley fuel regulator for a Weber?
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 12-03-2009, 11:58 AM   #1
wm69
Where do ya'll mount your Holley fuel pressure regulator when running a weber carb? I got my regulator in a couple of days ago and am ready to get a kit in the carb, get the regulator mounted, and get it back on the Jeep.
wm69 is offline   Reply With Quote Quick reply to this message
Unread 12-03-2009, 12:47 PM   #2
CJ Chet
My aluminum valve cover has some unused threaded holes so I put them to use.
Beer is the answer - it doesn't matter what the question is!
'86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift.
'04 AEV RUBICON.
'00 TJ Sahara.
CJ Chet is offline   Reply With Quote Quick reply to this message
Unread 12-03-2009, 02:08 PM   #3
JoonHoss
2011 JK Wrangler
as close to the weber as possible, after the filter, and after the split for the return line
Hoss
"Genius may have its limitations, but stupidity is not thus handicapped."
JoonHoss is offline   Reply With Quote Quick reply to this message
Unread 12-03-2009, 02:38 PM   #4
wm69
What kinda gauge is that? Where did you get it?
I've got a clifford cover on mine, but have the air cleaner for PB, so have to look and see what I have to work with. Raining here since my regulator came in so I haven't had a chance to look at it yet.
Unread 12-03-2009, 02:39 PM   #5
wm69
Hoss
Is yours mounted or did you just hang it in the fuel line? It's not heavy. I wondered if I couldn't just let it hang.
Unread 12-03-2009, 02:42 PM   #6
JoonHoss
2011 JK Wrangler
I let it hang- it barely moved with that short of a line, I didn't see the harm.
I suppose eventually, it would be slightly more prone to cracking the hose, but I didn't see it as significant risk.
Hoss
Unread 12-03-2009, 04:05 PM   #7
heath84CJ7
The gauge you can get from Summit. Mine is set up like CJ Chets!
heath84CJ7 is offline   Reply With Quote Quick reply to this message
