Where can I get quality rubber boots(Trans/tcase, etc)? - JeepForum.com
post #1 of 11 Old 04-17-2013, 02:42 PM Thread Starter
jp360cj
1977 CJ7
Several years ago I replaced the rubber boots around the transmission, tcase, clutch rod at the firewall, and clutch fork on the bellhousing.
They were very stiff and cracking within a matter of months. I have replaced the 2 for clutch once more since then and they have long rotted away. Not much left of the shifter boots either.
I believe they came from Quadratech or 4wd and were made by crown automotive. Anyone know where I can get some quality pieces that will hold up better?
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #2 of 11 Old 04-17-2013, 03:14 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Yep, the quality of the aftermarket rubber parts sux.
I'm still using the original 32-year old shifter boots and they don't have a single rip or tear on them. The brand new Crown boot I put on my 360's bell-housing lasted about 4 months.
I wish I had an answer for you, but it seems Crown and Omix are the only suppliers of some of these more obscure parts. I've decided to treat some of these parts like normal maintenance items, like changing filters, or rotating tires. Just buy extras and replace them as needed, I guess.
Matt
Matt1981CJ7 is offline
post #3 of 11 Old 04-17-2013, 03:40 PM
nosheep
1983 CJ7
I got some good ones from amazon.com
nosheep is offline
post #4 of 11 Old 04-17-2013, 05:23 PM
MoC
They are all crap these days. My last aftermarket one died after a little over a year. That was with keeping it covered at night and never getting rained on.
MoC is offline
post #5 of 11 Old 04-18-2013, 10:28 AM
VaCJ79
1979 CJ7
I gave up on the rubber shifter boots. Went through 2 in less than a year. I ended up going to an upholstery shop and had them make me some out of vinyl backed with a waterproof boat material. It was kind of expensive but works way better.
1979 CJ7 258 / 4.0 head / J20 power Steering / T150 Dana 20 / EMU YJ 2" lift / Custom front bumper
Looking for : Please PM, Carter 2 barrel Carb before you through it out
VaCJ79 is offline
post #6 of 11 Old 04-18-2013, 01:26 PM
CJ258
1974 CJ5
I bought a Spectre universal shifter boot from O'Reilley's a couple yrs. ago and it's holding up. Lo-kar has shifter boots, may be decent quality.
CJ258 is offline
post #7 of 11 Old 04-18-2013, 05:01 PM
gmakra
Ford and Chevy Dealerships still carry good sifter boots.
gmakra is offline
post #8 of 11 Old 05-13-2013, 07:21 AM
CJ7ROB
Anyone know if these for the T176 are any good? Or anyone replace it with one from another truck that worked just as good but better quality? thanks
http://www.quadratec.com/products/52109_01.htm
CJ7ROB is offline
post #9 of 11 Old 05-13-2013, 07:57 AM
JustDandee
1983 CJ7
How about using a CV joint boot, I have seen that done on a car and that worked rather well.
JustDandee is offline
post #10 of 11 Old 05-13-2013, 06:41 PM
keith460
Jeep. There's Only One
keith460's Avatar
I looked over some of the rubber pieces on my CJ-7 since it was restored and back on the road since 2011 and many of the aftermarket rubber and rubber/foam parts are deteriorating.
Steering column seal through the firewall is breaking apart.
Bell housing fork boot is ripped.
Shifter boot out of the trans is heat damaged and deteriorating.
Shifter boot on the trans cover is holding up well.
TC shifter boot on the trans cover is holding up well.
Rubber boot for manual shift rod through the firewall is ripped.
I believe Crown Automotive makes everyone one of them and shame on them for allowing inferior parts to be made in China. And that's not all, my Crown Automotive defrost knob just came off the end of the cable yesterday. Jeezish H...
Its unbelievable that they sell such crap. I'm writing an e-mail to them shortly but must first take photos for proof.
1984 CJ-7 Renegade
keith460 is offline
post #11 of 11 Old 05-14-2013, 07:35 AM Thread Starter
jp360cj
1977 CJ7
I've had similar problems with the control knobs too. The one for the fresh air vent came of within a month or two. And it wasn't from me pulling on it because I never use that one. It just fell of. The one for the heat came off a few months later. I ended up buying black aluminum knobs that I install with a set screw. No more problems.
jp360cj is offline
