Where can I get a Fan Shroud??? - JeepForum.com
post #1 of 5 Old 07-25-2002, 12:12 PM Thread Starter
Boots
Question Where can I get a Fan Shroud???
I have a 78 CJ5 and I need a fan shroud. It seems to run fine without it (at least before I disassembled the jeep), but I want one to make the engine compartment look better.
Who sells them? I've looked in my 4WD Hardware and Rosser catalogs, but no luck.
Thanks
Boots
Boots is offline
post #2 of 5 Old 07-25-2002, 12:45 PM
cjdriver
cjdriver's Avatar
www.mepco4x4.com sells them. their site sucks, but you can look up their number and call them.
Jim Sykes
motorsports photography
cjdriver is offline
post #3 of 5 Old 07-26-2002, 05:50 AM
Hooch
Boots,
A fan shroud to make the engine compartment look better?? Fan shrouds are a very important factor in keeping your engine cool. Without one, the airflow through the radiator and over the engine will be very inefficient as the air will "escape" over the tips of the fan blades. A fan shroud will force the air through the radiator and should not be discarded.
Failing finding one off the shelf, try wrecking yards or make one.. It isn't that hard...
'83 CJ-7 in Land Rover Country
Hooch is offline
post #4 of 5 Old 07-26-2002, 10:10 AM
Brock
Brock's Avatar
Call Leon Rosser's 800 number. I checked on one for my Jeep about a month ago. They don't print the huge catalogs anymore, just the brief small ones, but they stock almost anything you need or they get it for you. I've spent a lot of paychecks in there.
Brock is offline
post #5 of 5 Old 07-26-2002, 11:37 AM
CJ7Jeff
Collins brothers in Wylie Texas sells them on their website www.collinsbrosjeep.com. Check them out. Got some pretty neat stuff.
'85 CJ7 258 w/Weber Carb and Nutter Bypass. Dana 44's F&R, 3.73 gears with Trac-Loc rear. Always looking for peoples $0.02.
CJ7Jeff is offline
Fan shroud SonicR1 Jeep CJ Forum 4 02-05-2010 09:56 AM
Fan Shroud-Help! Rocket6R Jeep CJ Forum 27 07-20-2009 09:25 AM
Fan shroud Q's 4wheelinfool Jeep CJ Forum 3 11-16-2008 04:00 PM
Looking for Fan Shroud for 84 CJ-7 with GM 350 jbramble24 Jeep CJ Forum 1 03-09-2008 10:49 AM
Fan Shroud anyone... longlimb Jeep CJ Forum 10 05-05-2006 06:18 PM
