Where the >>BLEEP<< can I get decent battery terminals?? - Page 2 - JeepForum.com
post #16 of 21 Old 04-14-2013, 09:52 PM
gwolff
1978 CJ7
Napa has the quality parts and can also crimp the ends. Solder when you get home then heat shrink.
+1 on jeep hammers post(s) as usual.
gwolff is offline
post #17 of 21 Old 04-15-2013, 04:31 PM
turbogus
1978 CJ5
Since I discovered them I like these military type terminals;
This enables us to use the welding wire that JeepHammer mentions in his outstanding posts.
Even more recently I found a seller of these rubber booties for 'em (where were these guys when I had a '69 VW Bug);
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #18 of 21 Old 04-15-2013, 11:06 PM
Vitabrevis
When I worked at a chain auto parts store I had to change dozens of terminals with the universal ends. I don't think any of them ever fit snug, they sell shims for few bucks. I did see one idiot make his own shims out of a beer can....
Vitabrevis is offline
post #19 of 21 Old 04-16-2013, 12:43 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Originally Posted by james04si View Post
My PO changed over to a battery with side posts that screw in vs the regular top posts and that's one of the few "upgrades" that I kept. We won't discuss the wooden shelf he built on the inside of the fender to set the battery on without holding it down at all. Only problem I have had was the wonderful Walmart employees that said a battery with side posts would never work in my jeep because the book didn't specify that battery.
"Side posts" are a GM "innovation" - done to help lower hoodlines, without having to lower the battery in the engine bay.
GM took a few years, but they figured out that side posts are difficult for a number of high-current applications - not enough cooling airflow over the terminal/pad assembly, and large engines or extensive high loads can heat the pads up to the point where they melt right out of the battery case!
Most battery manufacturers recommend a limit of 75A through the side posts pad for more than a few minutes, for that reason. (That, and lead melts at low temperatures.) The exception is Odyssey - I believe they use brass, nickel brass, or nickel-plated brass for their pads, I haven't checked. But, they say "No problem" - even for a winch! I haven't had a change to verify how or why.
Based on information gathered from Exide, International, Autolite, and Optima, I typically recommend using side posts for accessory distribution up to 75A constant-duty, up to about 200A for infrequent use (up to two minutes out of an hour,) and not for winching at all!
Nota Bene: Starter motor loads for our beloved AMC sixes typically run 110-130A (no load) or 160-180A (cranking current.) Plan accordingly.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #20 of 21 Old 04-16-2013, 02:59 AM
John Strenk
John Strenk's Avatar
1976 CJ5
What do you mean by "110-130 amps NO LOAD" ????
Spark plugs out, throttle open, turning the engine over or starter spinning freely not connected?
Either way it should only take a few seconds to start an AMC i6 so if the post is clean ad tight, there should be no problem with overheating the side post terminals.
John Strenk is offline
post #21 of 21 Old 04-16-2013, 08:41 PM
james04si
james04si's Avatar
1977 CJ5
Right there with you john. I have had mine for the 15 years I have owned mine and never had any issues. My old 232 used to crank for a good 20 secs before it would start cold.(new 258 cranks immediately with TBI) that being said the most drain I had on mine was probably my old stereo with 3 amps for a total of 2800 watts. I don't have a winch though.
james04si is offline
