Where the >>BLEEP<< can I get decent battery terminals?? - JeepForum.com
post #1 of 21 Old 04-13-2013, 02:19 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
As you may have noticed I have been chasing electrical issues in my rig for some time now. The last was a 'No Crank' condition which I 'think' I resolved with dedicated grounds on the starting system components.
HOWEVER, when I finally go the rig to crank it seemed to crank a tad slow.
I assumed this was due to some nasty battery cable terminals.
I replaced them with some I picked up at the local Big Box store and even with the ground terminal tightened to the point that it was completely closed up, I could still wiggle the cable off.
So where can I get some 'decent' battery terminal ends so this thing doesn't sit another entire summer????
Thanks in advance....
2X
2Xtreme is offline
post #2 of 21 Old 04-13-2013, 02:37 PM
lucdog
1980 CJ5
Get them here.
http://m.summitracing.com/parts/mor-74175
My local speed shop carries them as well. Be sure they're rated for your cable size.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 21 Old 04-13-2013, 02:44 PM
Havasu Living
Havasu Living's Avatar
1980 CJ7
Had these guys make up a new + cable for my winch. A little $$$ but worked for me. Good luck.
80 CJ7 5.0 Dual Exhaust, T176, D300, D30 w/ true trac, AMC 20 w/ ARB 4.56 gears, York OBA, Hydroboost
Havasu Living is offline
post #4 of 21 Old 04-13-2013, 04:07 PM
Galt
Galt's Avatar
1983 CJ7
Read the pinned topic JeepHammer post on electronics 101 if you get the chance. It's really good.
I buy all my electrical terminals from wyotech. I don't have the link but they should pop right up in a web search.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
1993 RX7 1.3L Rotary/ GT40R turbo/484 rwhp
2002 F-150 Lariat 5.4L V8
2007 GMC Yukon Denali 6.2L V8
Galt is offline
post #5 of 21 Old 04-13-2013, 04:09 PM
Galt
Galt's Avatar
1983 CJ7
Sorry I had it wrong.
Here is the link. www.waytekwire.com
Enjoy.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
Galt is offline
post #6 of 21 Old 04-13-2013, 07:27 PM
Ivehad4
1978 CJ7
Might get me some of them. Would like to know why their prices are to 4 decimal places though? I'm running short of $0.0025 coins.
1978 CJ7 304/T150
1959 Willys CJ5 F4/T90
1995 XJ 4.0
1998 TJ 4.0
Ivehad4 is offline
post #7 of 21 Old 04-13-2013, 08:35 PM
scoutboater
1974 CJ5
Originally Posted by 2Xtreme View Post
... even with the ground terminal tightened to the point that it was completely closed up, I could still wiggle the cable off.
It sounds like you got a couple of "universal" type replacement ends at the store. It is not unusual to have trouble getting those to get a good grip on the negative terminal, since it is smaller. Before you go ordering online, go back to the store (or another store if you prefer), and ask for a pair of terminals, one positive and one negative. I don't know about the big box stores, but I do know that we keep them. Ours are in a box in the back (just the way they come), and they do cost a little more than the universals.
Be warned, the weekend moonlight parts flunkie will probably try to convince you that the universals will work, but now you know better. Explain the situation, and ask for the better ones. And don't be afraid to walk out.
scoutboater is offline
post #8 of 21 Old 04-14-2013, 05:54 AM
imafishingfred
imafishingfred's Avatar
1981 CJ7
Enjoy.
Waytek or here http://www.electerm.com/battery.html.
I've used both.
imafishingfred is offline
post #9 of 21 Old 04-14-2013, 09:45 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by scoutboater View Post
I.... and ask for a pair of terminals, one positive and one negative...
Well, in my defense they were painted red and black....
2Xtreme is offline
post #10 of 21 Old 04-14-2013, 09:47 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
I've used both.
Holy CRAP that;s a lot of options!!
2Xtreme is offline
post #11 of 21 Old 04-14-2013, 10:00 AM
JrTjK
1978 FSJ Wagoneer
Go to your local West Marine or any boat store and pick up marine grade terminals.
JrTjK is offline
post #12 of 21 Old 04-14-2013, 10:13 AM
ASteve
1972 CJ5
Originally Posted by lucdog View Post
Attachment 607123
Get them here.
I have the same ones. High quality, brass & great connecting mechanism.
SC
ASteve is offline
post #13 of 21 Old 04-14-2013, 11:19 AM
86cj74.2L
86cj74.2L's Avatar
If your not buying a molded battery cable your just asking for trouble.
The battery clamps that you jam the bare wire into the battery terminal and tighten the two bolts is a poor excuse for a good connection.
86cj74.2L is offline
post #14 of 21 Old 04-14-2013, 06:44 PM
james04si
james04si's Avatar
1977 CJ5
My PO changed over to a battery with side posts that screw in vs the regular top posts and that's one of the few "upgrades" that I kept. We won't discuss the wooden shelf he built on the inside of the fender to set the battery on without holding it down at all. Only problem I have had was the wonderful Walmart employees that said a battery with side posts would never work in my jeep because the book didn't specify that battery.
james04si is offline
post #15 of 21 Old 04-14-2013, 08:30 PM
silentmike29
1986 CJ10
I got mine at advanced auto parts...they are tool-less and you lift the arm up, tighten the thumb screw, and close the arm again with clamps around the post...they work pretty well and solved my battery draining issue i had with a loose negative terminal.
Roll one. Smoke one. When you live like this you're suppose to party..
silentmike29 is offline
