Quantcast Where are all the body mounts on a 76CJ7? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Where are all the body mounts on a 76CJ7?
Old 09-04-2007, 10:17 PM   #1
part.changer
1976 CJ7
I'm going to install a body lift soon on my 76CJ7.
From what I understand, it just entails changing all the body mounts and then making any necessary adjustments (4WD handle etc.).
If this is correct, and please tell me if it's not, I've been looking for all the body mounts.
I've only found a few so far. Can someone tell me exactly where they all are, so I can prepare appropriately (soaking them with PB Blaster).
Below are the ones I've found so far. If any of you want to make any type of mark with an image editing program, I'll finish it all up with a final diagram with all locations marked, for future reference.
part.changer is offline   Reply With Quote
Old 09-04-2007, 10:20 PM   #2
kavephish
1981 CJ5
There's one under the grille too.
kavephish is offline   Reply With Quote
Old 09-04-2007, 10:20 PM   #3
supraman1990
1980 CJ5
Theirs one in the center under the radiator.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline   Reply With Quote
Old 09-04-2007, 10:24 PM   #4
part.changer
1976 CJ7
Revision #1:
Old 09-04-2007, 10:25 PM   #5
jeepskate
Crack open your Chiltons or Haynes, there's a diagram in the back that's also posted on the internet that shows all of the locations...there's 11 of them.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
http://www.jeepskate.net
jeepskate is offline   Reply With Quote
Old 09-04-2007, 10:30 PM   #6
part.changer
1976 CJ7
I definitely looked on the internet, and I haven't found it in my Haynes. I come here liberally because I figure adding diagrams to the JeepForum archives will only help others.
Old 09-04-2007, 10:47 PM   #7
jeepskate
Been posted here several times before so if you couldn't find it odds are your diagram won't be found either Here's one link:
http://www.4x4review.com/tech/jeep-frame-specs.asp
Do yourself a favor and invest in a reprint factory service manual, it'll save you a lot of headaches.
Old 09-04-2007, 10:55 PM   #8
part.changer
1976 CJ7
I will buy one of those soon. I thought Haynes was the Bible, but, the more I get into this, the shallower I realize that book can be. It's great and all, but it leaves out alot.
Old 09-04-2007, 11:10 PM   #9
part.changer
1976 CJ7
Well, as my penance for failing to find this diagram myself, I have cleaned it up for just this purpose.
Glock Forum
