Quantcast when putting a YJ top on a CJ... - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > when putting a YJ top on a CJ...
Old 04-29-2007, 08:48 PM   #1
CJ7 Vette
I know there is a latch issue at the tailgate, but will everything latch closed/locked without modification? Can I just open the tailgate from the inside to work around the issue?
84 CJ7 new 258,Howell TBI, Borla header/exhaust, clutch, repainted engine compartment,frame and most of undercarriage,jks discos and a host of other new stuff under the hood :)
update: no rust, new floors, stripped, primed, filled, blocked, and repainted with PPG Concept Garnet Metallic. Hardtop freshly painted, all trim painted in black metallic with a bit of flatener mixed in. New seats, carpet, console, roll bar pad, seat belts,dash, flares, windshield, seals, tire carrier and more!
CJ7 Vette is offline   Reply With Quote
Old 04-29-2007, 09:14 PM   #2
SuB8HaVeN
If you mean the hardtop, yes it will fit OK except for the tailgate issue, which is more of an annoyance than a problem.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline   Reply With Quote
Old 04-29-2007, 09:21 PM   #3
CJ7 Vette
so everything latches, I would just have to latch/unlatch from the inside?
Old 04-29-2007, 09:36 PM   #4
SuB8HaVeN
Yes, all the mounting holes on the tub should line up and everything. The doors are also interchangeable, or so I've heard.
Old 04-30-2007, 01:16 AM   #5
only in a jeep cj
CJ OWNER FOR LIFE
My buddy had a YJ top on his CJ and it was a HUGE pain, if I remember correctly, he had to open the tailgate, then close the tailgate and the lift gate at the same time, but turn the liftgate handle to shut the liftgate,but the tailgate was left loose unless he climbed in and latched it from the inside.....I found a YJ with a CJ top on it and hooked the two up to trade.....each was way happier and saw how it was supposed to work.....JUST get a CJ top.
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote
Old 04-30-2007, 07:54 PM   #6
CJ7 Vette
thanks, I actually found out it IS a CJ top. The wife told me it came off their 95 wrangler, but didnt tell me it was originally on their CJ7. thanks!!
Glock Forum
