wheele spacers!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > wheele spacers!!!
G2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ ChIron Cross Customer JK and TJ Wrangler Bumpers now at ROCKJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 11-17-2014, 09:16 PM   #1
caleb1234
1975 CJ5
wheele spacers!!!
need you guys feed back on wheele spacers. i am running a 31x10.5 butt i want a wider track on my cj5 should i get a 31x12.5 tire or add some 2 inch spacers what are the pros and cons.
caleb1234 is offline   Reply With Quote Quick reply to this message
Unread 11-17-2014, 09:39 PM   #2
BagusJeep
BagusJeep's Avatar
1981 CJ7
Will the tyres fit your rims?
The wider tyre you will be 2" wider overall but the inside of the tyre is now 1" nearer the frame and suspension, have you got the space? It depends on the backspacing of the wheels you already have. They are also a wide tyres for a CJ, not a major issue as such.
Spacers will give you more backspacing but you can achieve the same with new wheels. I have some on Bagusjeep and they work OK, but the 31" tyres are now well out past the fenders. That meant extending the flares.
In terms of cost the spacers will be the cheapest option but get some properly made ones, not the eBay made in china.
Pictures below. I think the spacers are about 1 1/2". Wheels are unknown. Tyres are 31x10.5 M/T
img00053-20110723-1413.jpg   img00245-20111022-1743.jpg   img00585-20120930-1804_2.jpg   img01045-20131026-1501.jpg
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread 11-17-2014, 09:47 PM   #3
caleb1234
1975 CJ5
that looks really good the thing is the tires are pretty much brand new on eagle aloy rims thats y i gave the spacer option a try.
Unread 11-17-2014, 10:07 PM   #4
dg6772
With spacers, you put more stress on your wheel bearings. Not a huge issue, just be aware and take the time to make sure all is properly greased. Shouldn't have much trouble I wouldn't think.
Dave in Muskegon using JeepForum app
dg6772 is online now   Reply With Quote Quick reply to this message
Unread 11-18-2014, 08:15 AM   #5
WindKnot
WindKnot's Avatar
1977 CJ7
Have we really established that? Intuitively I believe that to be true also, but how would spacers be any different than changing the backspacing on your wheels?
Or would you be doing the same thing?
Enquiring minds (well half of one anyways) want to know!
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration? http://www.jeepforum.com/forum/f8/ph...ation-1807257/
WindKnot is offline   Reply With Quote Quick reply to this message
Unread 11-18-2014, 08:31 AM   #6
dg6772
Hmm, good question. I'm just going by the info I was given when I changed my backspacing on my 3/4 ton truck to allow me to run 15" tires. Much bearing failure with multiple manufactures until I returned to 16" and a reasonable backspace. I may have been misled. Dunno....
Unread 11-18-2014, 09:24 AM   #7
CSP
Anything that adds leverage to the side load on the wheelbearing is going to shorten its life. It doesn't matter if it's wheel spacers or a wheel with more less backspacing.
How much shorter though? I would think it depends on too many factors to accurately give a number.
CSP is offline   Reply With Quote Quick reply to this message
Unread 11-18-2014, 11:11 PM   #8
Unretarded
1963 CJ5
I just priced out good spacers for mine..........as I am in sort of the same boat.......good quality spacers...approx 400 dollars......good quality steel rims...approx 230.......
I also agree it causes more bearing load.....but how much leverage do you get with a 1 inch pry bar......I would venture to guess a 5 percent reduction in life and increase in load factor would be a extreme worst case.
My 3/4 ton truck uses a dually rear end,non dually truck, with 3/8ths spacers to make up for the lack of a second rim for lug nut depth from the factory....I would guess virtually zero difference in bearing life....one inch can not be that much more.
Jeep...the first vehicle on the moon.....next trip we are bringing the tub!
It is gunna cost more and take longer than you thought...plan ahead!
Unretarded is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 03:54 AM   #9
skizriz
skizriz's Avatar
1978 CJ7
I have 4 Rugged Ridge spacers 1.5" that i will be taking off of mine this weekend. $100 + shipping.
Sent from my HTC One SV using JeepForum
78 CJ7 258 TH400/Dana18 SOA/stock YJ springs 35" General Grabbers.
skizriz is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:55 AM   #10
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
$400? Huh? Spidertrax, which are considered some of the best spacers, are $99.99 for a pair at Q-tec.
These are what I've run for 3 years without any issues.
http://www.quadratec.com/products/92807_002.htm
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:42 PM   #11
Jeepn-n-tx
I go by "Mike Honcho" ...
Jeepn-n-tx's Avatar
1981 CJ7
I run the spidertrax on mine narrow track axles and I'm very pleased. Since I wanted to keep the OEM Laredo wheels, new wheels with deeper back spacing was not an option. $200 & about 20min and I was done.
Then only con I've found is that I couldn't use the OEM center caps for the front wheels due to the locker hubs. The spacer placed the new lug studs right next to the bolts for the hub body. There are picks in my build thread.
Is it snobby I don't wave at 4-door Jeeps? :)
-Scott
'81 CJ7 Rebuild ... http://www.jeepforum.com/forum/f8/my...oject-1543726/
Jeepn-n-tx is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:02 PM   #12
Unretarded
1963 CJ5
Matt
My bad..."adapters", not spacers, just looked and spacers are considerably cheaper than adapters.......
Unread Today, 08:47 AM   #13
AdamH07
I have run Spidertrax on multiple Jeeps (old JKUR, CJ7, 2 TJs, soon my LJ, and the Commander I just sold) over the years and currently have them on my Scrambler (wanted to keep narrow track axles and factory 15x8s and have 35x12.50s on it.) Never a problem.
'06 Rubicon LJ, Impact Orange
'81 CJ8 Scrambler
'14 JKU Rubicon
AdamH07 is online now   Reply With Quote Quick reply to this message
