Wheel spacers? - JeepForum.com
post #1 of 4 Old 09-25-2002, 09:00 PM Thread Starter
jeepin cj-5
Wheel spacers?
Does any one use wheel spacers? I hanvt heard too much about them. Are they any good and are they reliable?
jeepin cj-5 is offline
post #2 of 4 Old 09-26-2002, 08:16 AM
dana60cj
dana60cj's Avatar
I know they put un-needed stress on the bearings and other components and they put your wheels out further. The bigger you get, the more un-needed stress. This could be done safely with a rim offset.
dana60cj is offline
post #3 of 4 Old 09-26-2002, 05:54 PM Thread Starter
jeepin cj-5
What is a rim offset
post #4 of 4 Old 09-26-2002, 10:27 PM
only in a jeep cj
offset= the relation of the rim mounting surface compared to center line of rim width. Example: 15x7 CJ rim. 7 inches is inside bead to inside bead, rim is 8 inches overall with a centerline at 4 inches and backspacing of 3.5. Backspacing is distance from the inner edge of the rim to the mounting surface. So that's 1/2 inch negative offset. Negative because the mounting surface is on the inside section of the centerline.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
Wheel Spacers 78treehugger Jeep CJ Forum 18 10-11-2009 08:04 PM
Wheel Spacers TJQ09 Jeep CJ Forum 1 09-29-2007 07:38 AM
Wheel Spacers armoroffroad Jeep CJ Forum 11 01-21-2007 08:38 AM
Wheel spacers Blthomas Jeep CJ Forum 5 02-05-2006 08:27 PM
wheel spacers randomhero350 Jeep CJ Forum 2 10-24-2005 06:42 AM
