Wheel size on a CJ7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Wheel size on a CJ7
Engo winch sale-- Best deal you will find. and FREE SHIPPIFree Air Compressor with Purchase of ARB air lockerIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-23-2007, 06:24 PM   #1
Jimthejeepman1
1978 CJ7
Wheel size on a CJ7
I am currently running 15x7 wheels with 33x12.50 tires on a daily driver cj7. I think the back spacing on the wheels is 3.5 or 4 inches and I have spacers in between that kick the tires out another 1 or so........ My question is, does anyone sell a zero offset rim or something else that will kick the tires out a bit farther than these wheels..........I am having some issues with the tires rubbing when i turn...
any ideas or thoughts would be appreciated
Jimthejeepman1 is offline   Reply With Quote
Unread 11-23-2007, 06:53 PM   #2
kappa505
1980 CJ5
You might want to consider a body lift or suspension lift.
"Nothing in the world can take the place of Persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan 'Press On' has solved and always will solve the problems of the human race." Supposedly President Coolidge
kappa505 is offline   Reply With Quote
Unread 11-23-2007, 10:22 PM   #3
Jimthejeepman1
1978 CJ7
I have a body lift and a suspension lift, thats not where its rubbing. The tire is hitting either the frame or leaf spring when i turn sharply. I need to move the tire out farther to increase the width, i think.......
Unread 11-23-2007, 10:29 PM   #4
bjf498
1983 CJ7
What kind of tires. Look at us wheel they will have what ever you want. you may just need to set your turn stops.
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline   Reply With Quote
Unread 11-23-2007, 10:43 PM   #5
gojeepin
gojeepin's Avatar
1983 CJ7
If your current 7" rim has 3.5" or 4" backspacing you've got either .5" negative or no offset.
If you buy an 8" rim with 3.5" backspacing you'll have a one-inch negative offset.
Your spacers add one-inch negative offset to either combination. That should already be enough to clear the frame if you have wide-track axles.
gojeepin is offline   Reply With Quote
