wheel cylinders - JeepForum.com
post #1 of 5 Old 06-18-2003, 05:56 PM Thread Starter
rustyCJ
wheel cylinders
how do you test wheel cylinders to find out if they are good or not? i installed new hardware and shoes on a rear 20 with 11" brakes today and the drums fit so tight they will barely spin with the adjuster in all the way. i am assuming its the wheel cylinders are just bad but would like to test them before buying new. so how you test them?
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #2 of 5 Old 06-18-2003, 09:01 PM
fuzz401
1978 CJ7
the only thing i know is if they leak or not could try to push them in and see if they slide back and fourth
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 5 Old 06-18-2003, 09:18 PM
tgc79cj5
I just recently finished rebuilding my rear brakes.........shoes, hardware, wheel cylinders...........but when I put my drums back on they were too tight, even with the adjustment loosened.
Drove me crazy until I figured out that my e-brake cables were frozen and the shoes would not set properly and were forced against the drum.
Just something to check. Good luck!
1979 CJ5
304 V8
T150 3 speed
Dana 30 Front
AMC 20 Rear
Dana 20 Xfer
BFG ATs 33x12.50
New Bestop Seats
tgc79cj5 is offline
post #4 of 5 Old 06-18-2003, 09:24 PM Thread Starter
rustyCJ
i dont have ebrake cables and dont have the ebrake bar(cant think of what it is called) installed.
i dont know if the cylinders are pushed all the way in or if they are stuck out. i dont want to press on the pedal and blast the cylinders apart if they are good either.
rustyCJ is offline
post #5 of 5 Old 06-18-2003, 09:54 PM
only in a jeep cj
peel back rubber boots and look inside. if all rusted or damaged, replace it. also use pressure on both sides and see if the 2 pistons inside slide back and forth EASILY, if not replace it.....IMO, replace it if you are unsure, they're 10 bucks each at autozone and you already have it all apart...why not. as for as it being tight, are the shoe frames resting properly on the piviot pin at the top, if not, your pistons are not fully compressed and the drum will be tight
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
My 258 has 160-165 psi on all cylinders...should I leave it alone? 243 Jeep CJ Forum 9 07-21-2009 09:27 PM
Different size front wheel cylinders on driver's side and passenger's side ariasbunch Jeep CJ Forum 3 07-13-2009 12:46 PM
MPI running on only 3 cylinders bpal Jeep CJ Forum 5 12-16-2007 10:14 PM
Running on two cylinders? crabman Jeep CJ Forum 3 01-16-2006 04:54 PM
Missing cylinders 85CJ7 Jeep CJ Forum 2 12-04-2005 01:09 PM
